2001 Mitsubishi Eclipse Spyder Logo
Anonymous Posted on Dec 10, 2017
I was messing with the after market stereo and the factory amp in the Eclipse spyder 2001, now the windows and the top will not do anything? What did I mess up? I didn't originally take the negative cable off the battery. Did I blow a fuse or what? I checked the fuses in the dash and didn't see anything wrong
toddgilbert
Level 3:
Top Expert:
  • Mitsubishi Master 6,360 Answers
  • Posted on Dec 10, 2017
toddgilbert
Mitsubishi Master
Level 3:
Top Expert:
Answers
6360
Questions
5
Helped
1526636
Points
27737
5 Related Answers
Anonymous
  • 1990 Answers
  • Posted on Jan 24, 2009
SOURCE: radio code Eclipse Spyder,how do you enter
Contact your local Dealership and ask for Parts. They have all the Codes and can tell you by Running your VIN Number.
Anonymous
  • 140 Answers
  • Posted on Mar 12, 2009
SOURCE: i am trying to install new stereo in 2003 spyder eclipse
IF YOU GO TO WALMART AND BUY THE WIRING HOOK UP KIT THATS MADE JUST FOR YOUR TYPE OF CAR U SHOULD NOT HAVE ANY PROBLEMS.. YOU CAN DO THE AMP BYPASS, OR YOU CAN INSTALL YOU NEW DECK AND REWIRE THE SPEAKERS DIRECTLY TO THE NEW DECK.. HOPE I WAS A HELP GOOD LUCK KEITH..
Anonymous
  • Posted on Apr 02, 2009
SOURCE: Changing the front speaker 2001 Eclipse Spyder
There are 7 screws all together to remove the door pannel. First, you have to take off the hanlde for the door. the 2 plastic covers on the handle pop off revealing 2 screws on the top and bottom, remove those. then behind the the door handle on the inside, pull it as if you were to open it and there is a screw that you have to remove. Then there are 2 screws on either side of the door pannel, both are farily close to the top, remove those, and then its just a matter of popping the pannel off. start from the bottom, pop it off then slide it up. becarefull, after the door panel is free, there is a connection for the power doors and windows unhook that then the pannel will be free. after that the speaker will be right there and its common sense on removing that. good luck.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Aug 11, 2009
SOURCE: what size after market in dash dvd can I put in 2003 spyder gs
your radio/dash opening DIN size is what they call double DIN, to get the right unit fopr this u will need to know if you have a Facory Infinity premium sound system, it makes a diff in the model f the in dash units, here is a link to a site that has a selection of in dash DVD players for your double DIN dash.
http://www.crutchfield.com/S-nkinM0jziRR/cgi-bin/autoinfo/autoinfo.asp?id=&vehicleid=14718&vb=Y&TypeCH=&lp=%2Fg%5F168550%2FIn%2Ddash%2DDVD%2DReceivers%2Ehtml%3Ftp%3D20217&sl=Y
Anonymous
  • 3 Answers
  • Posted on Sep 09, 2009
SOURCE: 2002 Eclipse Spyder stereo not working after floor was wet
Remember the amplifier in a Spyder is under the passenger seat. So it could have shorted out.
01 eclipse spider top and rear windows do not work
All three wire showing 3 it should be all 4 wires, In the back of the rear seat is the convertable top module, the yelloow black wire should go ground to bring it down.Other than that a new module will be needed,this gets its command from the window main switch so see if yellow/black wire switches over
2003 eclipse spyder gt. display window on the infinity stereo doesn't illuminate.
unfortunately the backlighting on these radios is not serviceable, you can attempt to have someone repair the radio, but better off getting a new factory one, wrecking yard one, or going with an aftermarket unit
TRYIN TO GET A DIGRAM TO SHOW ME THE LOCATIONS AND NAME OF EACH SENSORS ON A ECLIPSE SPIDER 2001
Here you are!
http://tearstone.com/eclipsefsm/70.PDF
BTW tearstone.com also hosts the rest of the factory service manual if you need to find anything else
Mitsubishi Eclipse Spyder 2001 what fuse for the power windows part #
I've been messing with the stereo and took the seats out to check the amp. I don't think I disconnected the negative cable on the battery and now the windows won't do anything and the top won't go up or down. What did I screw up?
1helpful
2001 mitsubishi spyder leaks above driver side window when it rains where do i get replacement weather stripping or do i have to replace the whole top?
te stops may have to be adjusted but must be done professionally or window can hit top when shutting the door . Also inspect the seal .
3helpful
2answers
6helpful
Wiring after market stereo to factory wiring equipt with factory amp
you have to get the cable that conects your factory deck harness to the aftermarket deck, and that will allow you to use your factory speakers and amp, the wire harness is availiable at canadian tire or any stereo shop
How to let down top of 2001 eclipse Spydar
first unlock latches locate up on roof under the sunvisors.
then roof switch located on center consoul just before the shifter. back to you to open, and forward to close.
if that dont work then check fuse
if not that check wiring.
if not that then its the motor.
I am trying to install new stereo in 2003 spyder eclipse
1helpful
3answers
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
