Cars & Trucks Logo
Posted on Sep 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the timing for my 2000 chevy cavillier 2.2
Roger Foster
Level 3:
President:
  • Master 701 Answers
  • Posted on Sep 08, 2011
Roger Foster
Master
Level 3:
President:
Answers
701
Questions
Helped
437611
Points
3451
Hello mpacovsky: My name is Roger and I will help you. There are no timing specs for your vehicle. Static timing is set when the timing chain is installed. This is the only timing you can do. All advance and retarding is done through the on board computer. The computer controls all of the timing.
Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
2helpful
2000 chevy silverado, runs for a while then dies and will not restart
Hi Beverly, I believe you may have a problem with the fuel filter or fuel pump. Regards John
2000 1.3l chevy metro cam and crank shaft position sensor resistance
00 chevy metro 1.3l just replace head gasket and had head work new timing belt timing/compressing good reassembled adjusted valve attemp to crank and #1 #3 s/plug foul #2 #4 good need help
1helpful
How can i set the timing on a 2000 chevy impala
you only need to set timing on the engine NOT the gearbox.
2answers
Tensioner on 2000 chevy tracker 2 litre
the plungr may be bad try a new one
2000 chevy tracker egr gone bad what are opitons to fix
usually egr sensor goes bad sometimes tube best to use new parts old ones may not work andwork short time
How do i change both headlights on my 2002 chevy cavillier
Removal & Installation To Remove:
  1. Remove or disconnect the following:
    • Hood close out filler panel.
    • Bolts from the headlamp.
    • Headlamp from the headlamp mounting panel.
    • Electrical connector from the headlamp.
    • Headlamp bulb/socket retainer ring from the headlamp.
  • Headlamp bulb/socket from the headlamp.
  • Bolts from the headlamp adjuster mechanism.
  • Headlamp adjuster mechanism.
  • To Install:
    1. Install or connect the following:
      • Headlamp bulb/socket to the headlamp.
      • Headlamp bulb/socket retainer ring to the headlamp.
      • Headlamp adjuster mechanism to the headlamp housing, if necessary
      • Bolts to the headlamp adjuster mechanism. Tighten to 6 N.m (53 lb in).
      • Electrical connector to the headlamp.
      • Headlamp to the headlamp mounting panel and lower mounting bracket.
      • Bolts to the headlamp. Tighten to 10 N.m (89 lb in ).
    1helpful
    02 Chevy Blazer Audio Wiring Diagram
    they are your speeker wires. the best the to do is to hook up the colors that are the same color to the color wires on the back of the radio. dont hook them all up at once two colors at a time.by doing this it will let you know what speaker you have hooked up.
    3helpful
    I need a diagram of fuse box for 2000 Chevy Express Van
    i have a 2000 Chevy van where is the fuse for the two(2) rear power outlets
    Top Chevrolet Experts
    ZJ Limited
    ZJ Limited
    john h
    Thomas Perkins
    Thomas Perkins
    Are you a Chevrolet Expert? Answer questions, earn points and help others
