When I turn on my projector, the green power light comes on and the fan turns on for a split second and turns off then nothing happens. The bulb is fairly new maybe 1/2 lifetime.
I have same problem. The green light comes on but my fan and lamp don't. I cleaned the filter but still nothing. I would buy a lamp but with the fan not coming on either, I don't know if that will solve the problem.
Same problem here. Lamp won't come on. Standby/On light blinks for 30-40 seconds, then lamp light flashes and projector goes to Standby. New bulb just installed. If I reseat the bulb, projector works for a little while.Same problem here. Lamp won't come on. Standby/On light blinks for 30-40 seconds, then lamp light flashes and projector goes to Standby. New bulb just installed. If I reseat the bulb, projector works for a little while.
same problem. We replaced the bulb. Unit powers on with no light and then off again. Took it to repair shop who thought it was the ballast. When replacing that didn't work, they contacted Panasonic. Still waiting for our projector to be fixed. They have another unit with the same problem in their shop. Panasonic Tech Support told me they would contact their Repair shop.
I have exactly the same problem. Green light, no fan, no map light. Cut out very suddenly and now won't work again. + Can't switch off using power button. I have exactly the same problem. Green light, no fan, no map light. Cut out very suddenly and now won't work again. + Can't switch off using power button.
You can't post conmments that contain an email address.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
check this out... http://www.ihatedell.net/forum/phpBB2/viewtopic,p,36316.html
have almost the same problem. lamp light turned on-->replaced the bulb, now when you turn it on tryies to boot and then the lamp light is on again (but the bulb is brand new).... and no light at all coming out of thing... I guess dell just don't know how to built projectors right way.... and theirs tech support guys are.... they just don't know about projectors more then manual
