It is likely a coincidence but you may have a restriction of the water downstream from the device. This would cause a higher pressure and might therefore add to the stress on the backup device. Regardless of the cause you still need to new backup valve or a new part to replace the part that split. They are not hard to replace if you can get it apart.
If you have trouble getting it apart you can bring it down to Leslies Pool Supplies and they can put it back in order for just the price of parts.
I hope this helps.
SOURCE: Have had my current Polaris
I think it is a coincidence. On the other hand, there could be a restriction downstream causing the pressure to be too high. I would check for this but either way you will need to buy a new one. I hope this helps.
Sorry...case, not cast.
