1992 Chevrolet C1500 Logo
Posted on Aug 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have power window switches on both the driver and passenger panels. Passanger window does not move. I checked the passanger switch and have 12 volts to switch; however, on the brown wire to the motor no power. Thinking the problem is in switch. However before I replace the switch I was wondering why the switch on the drivers side doesn't open the window. I know there are 5 wires to the switch and does one of them come from the drivers door swich and bypass the passenger switch to the motor. Finally how do I definative determine if the switch is bad? thanks CB
Anonymous
Level 2:
New Friend:
  • Expert 176 Answers
  • Posted on Aug 30, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
176
Questions
0
Helped
42799
Points
489
POWER GOES TO THE DRIVERS DOOR TO OPERATE BOTH ;RUNS MOTER ON PASSINGER DOOR; PASSINGER DOOR RUNS IT`S OWN POWER; CHECK CONNUITY IN THE SWITCHES AS YOU PUT THEM IN THE OFF ON POSITIONS !?
1helpful
My passanger front window is stuck in the down position. Could this be the window switch?
The same thing happend with my 94 lesabre. I thought it was the switch but i realized that the switch was fine. I went at the junk yard and got my self a power window motor. That is proboably what is wrong with your windows. I recommend that you get yourself new or used window motors and that sould do it!
Best of luck
2answers
2000 ford f250 passanger side window wont go up
Check the wires on the driver's door between the door and the post. A break in a wire will affect the passenger side.
2004 chevy venture: driver's electric window hesitates when trying to lower or raise it. Do I need to replace a switch, motor, etc.?
if you have fully charged battery and you are having this problem well i would take the door panel off and watch it operate make sure every thing is moving smoothly and lubed if you can switch the switches from passenger to drivers test both see if the drivers window operates normal same with other side if no change then yes find new motor on craigs list .com hope this helps you out
Passenger side power window won't go up or down
Does it NOT work from either switch (passanger or drivers?) Check switch it good, replace window motor.
2answers
Which relay switch do i replace for powers windows on 2002 ford wind star van, drivers window and back sides work passengers doesnt work i was told to replace relay I dont know whick one to replace
Doubt it is a relay,all but one window works! Are you just going to buy a new one,without knowing if it is the problem?
Check the pass window switch.
Switch,okey,remove door panel and check out motor
1998 VW Jetta GLS Manual Trans. The driver side power window won't roll down. From the same switch the front passenger window won't up but will roll down. The passenger side switch works fine; passanger...
If you have a multimeter you can go to the underside of the master panel in the drivers door and independently check the switches for voltage or with no power to the switch assembly check for continuity. Good place to start. If you get continuity to through the switch then you need to check power to the window actuators in the doors.
My 2001 venture van passenger power window will power down, but not up....driver switch has no response now to passenger door window ?
Now you do not have any response at all up, or down ?
I would say fuse has been blown to that side, but the bigger problem is that I believe the window motor more than likely has failed.
You will have to remove the door pad and using a volt meter find if you have 12 volts to the motor while operating the switch.
If you have 12 volts, then I would say motor is bad.
If you do not have 12 volts, then I would trace wiring back to switch, look for continuity.
Please let me know what you find.
3helpful
2answers
Driver side power window not working. how do you know if its a switch or motor. I have door panel off and hoped to use passanger side switch to make sure before i replace motor.
you can test the voltage that comes out of the switch, if no voltage, then switch is bad. If there is 12 volts coming out then the motor is bad or dirty.
3helpful
Passanger window does not go down from driver power window switch
The control switch on the drivers door is bad if the window rolls down using the passenger switch
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
