F 35-i thru f35-6 low temtemperature or open thermistor
simulations
note : 9272 is the standered password to enter simullation press9,2,7,2,start , to use these with power already on press and hold the"*"key util the display says "please enter service password"note:factory manual says"keep pressing" this might mean hold down or it might mean press repeatedly.press9272 start "mode selectmenu screen" will appear.press the mode you want[p ,25, 35, 36 , or 47] when finished press "normal mode"to return to standard screen use the number keys to change values press print key to check item press "stop/clear"when finished
"25 mode" to enter this mode turn power off, press the 2and 5 keys and hold them down while they are held down turn on power menu screen will list choices
1 software switches
2pm count
3collectng
select your choice enter value press"return"to see that your new value has been entered turn power off new in formation will not take effect util power is off and back on again
1 software sw ....use up/downarrows keys to select dip switch use up/down arrow keys to select to select bit number"on"is 1 "off" is "0" on will set bit off will clear bit press "return"to return to menu listing dipswitches and all their bits cannot be done in a short publication such as this one
dipswitch 3 bit 1 is the fuser reset command {for error cdes f34,f35and f36}0 is no 1 is yes to reseta fuser fault you enter this mode select dipswitch 3, select bit 1and change "1"to "0"by pressing"off"
dipswitch 23 bit 7 is fuser web count-over stop machine will stop operating when fuser web life is reached if this is set to"1"
