20 Most Recent Konica Minolta 26NA53040 7130 7025 7020 Oem Lower Fixing Roller Assy New Questions & Answers
The printer stops working & showed me an error code F-26-1
www.fixya.com/.../t16683015-printer_stops_working_amp_showed_me
Feb 20, 2013 - the printer stops working & showed me an error code F-26-1 , How can I repair it ? I think it s relating to a - Konica Minolta 26NA53040 7130 ...
Konica Minolta 26NA53040... Repair Questions - Fixya
www.fixya.com/.../p4700437-konica_minolta_26na53040_7130_7025_...
Konica Minolta 26NA53040 7130 7025 7020 Oem Lower Fixing Roller Assy New ... Theprinter stops working & showed me an error code F-26-1 , How can I ...
Konica Minolta... | Answered on Dec 26, 2015
Remove the drum cartridge, then remove developer unit, then the charge housing above the drum the remove the drum do not touch it has to be done from the side of drum. once removed then is sensor that has a white cover on it, there is also a clear one white one is in the rear on the left side clean DO NOT USE A VACUUM Cleaner the static electricity will destroy the sensor. Then re install. run all required check . Unless you know what you are doing get a qualified Konica Minolta Technician Has to have Konica Experience You have a legacy Konica machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Feb 09, 2015
Replace the fuser unit. then reset, with procedure:
Konica Minolta... | Answered on Jun 07, 2019
11.5.4 MAINTENANCE COUNT.
A. Use
• To display the count of the maintenance counter.
• When the counter reaches "0", maintenance call M1 or the service call will appear, according to the setting on MAINTENANCE COUNT. of SERVICE'S CHOISE.
See P.85 below
e
• To enter an appropriate counter value (0 to 999999) as the tentative maintenance time.
• Specify the setting on maintenance counter to "1" or "2": If the maintenance life is
reached, the maintenance call (M1) or service call [Call Service (M1)] will appear.
"0" : Not counted
1 : Counted (The maintenance call display is given when the counter reaches 0.)
2 : Counted (The service call display is given and the initiation of any new copy cycle
is inhibited when the counter reaches 0.)
NOTE
• The counter value is decremented until it reaches -999999 even after it has
counted 0.
B. Procedure
• The default setting is 0.
• When "1" or "2" is selected, a screen will then appear to allow the counter value to be
entered.
• To clear the count, use [CLEAR DATA] of the SERVICE MODE.
Procedure below to enter::
11.2.1 Starting procedure
1. Press the Menu/Select key.
2. Press the following keys in this order.
Quick Settings Quick Settings left arrow twice the right arrow then left arrow
11.2.2 Exiting procedure
• Press the Back/Stop/Reset key as many times as it is required to display the initial
screen.
11.2.3 Changing the setting value in SERVICE MODE functions
1. Select the desired item using [??/??/??/??] key.
2. Select the setting value using [??/??/??/??] key.
3. Validate the selection by pressing the Menu/Select key.
4. To go back to previous screen, press the Back/Stop/Reset key.
Konica Minolta... | Answered on Jun 06, 2019
Do what it says and call service.
Hello, this is related to Magenta write ulit/laser unit. Check connecters both to write unit and that of pcrb. Mostly this error come after removing and replacing the units. Otherwise replace the unit. Some time rewriting firmware clears the error but thos should be the final option.
Konica Minolta... | Answered on May 31, 2019
Could be that the tab that acturates the sensor to tell the copier the door is closed is broken,check the door itself any damage to the tab or the senor the tab acturates is dirty or broken from its mount or bad
Konica Minolta... | Answered on May 22, 2019
Contact Konica Minolta directly to inquire.
Konica Minolta... | Answered on May 08, 2019
Check the drum and developer
Konica Minolta... | Answered on May 07, 2019
Do you have a print controller IC 409 with this machine need to know prior to continuing to trouble shoot.
Have problem with the control board and image control boards
Konica Minolta... | Answered on Apr 28, 2019
Sir, Check the slit glass for the print head (LASER)
Konica Minolta 26NA53040 7130 7025 7020 Oem Lower Fixing Roller Assy New Logo
2 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
printer konica minolta stopped working
  • Office Equipment & Supplies
