http://www.helpowl.com/p/D-Link/3350SR/Research/20945?search=des%203350sr%20setup
DES-3350SR Layer 3 Fast Ethernet Switch Users Guide reset Restrictions Only administrator-level users can issue this command. Example Usage:
To restore all of the switchs parameters to their default values: local>reset config Command: reset config Success. local> login Purpose Syntax Description Used to log in a user to the switchs console. login
This command is used to initiate the login procedure.
The user will be prompted for his Username and Password. none. none. Parameters Restrictions Example Usage: 46
hope this helps
