20 Most Recent
Linksys SRW224G4 24-Port Ethernet Switch Questions & Answers
How to create vlan
Virtual Local Area Network (VLAN) technology logically divides a physical LAN into multiple broadcast domains, each of which is called a VLAN.
Each VLAN functions as a separate broadcast domain, with devices in the same VLAN able to directly communicate with one another, while those in different VLANs cannot. As a result, broadcast packets are confined within a single VLAN.
How to create vlan with
Login to the built-in web-server interface, and use the interface to add specific ports to a specific VLAN.
I have a switch and
The point of separate VLANs is to keep traffic on one VLAN from reaching the other VLAN. So, you asked for the two VLANs to be "isolated" from each other.
I forgot password of my
[1] Connect to the console port using terminal emulation parameters (typically 38400, 8, 0, 1, None)
[2] Reboot switch (Remove power)
[3] Hold down Ctrl U while rebooting
--[a] Menu will be displayed
[4] Select> [D] Delete file
[5] Type startup-config (be sure that this is the ONLY file that you delete - if you delete other files, you[ will have to reload the firmware)
[6] Now, you have erased the configuration file and you should be able to reboot and login with the default username and password.
I have linksys srw224g4 layer
Log into the web management of the switch.
Go to settings --> Vlan Tabb
Under the VLAN click on the VLAN and you can see the ports .
Click on the trunk box under the switch port which you want to make as trunk.
I want ot know how
Most linksys switches and routers use a simple management interface which is accessable through internet explorer.
Open internet explorer and type this address into the address bar;
192.168.1.1
and yes, the periods are important.
When the access dialog box opens, type in the user as "admin"
type in the password as "admin"
this should get you in.
If the user or passwords have been changed then all you can do is to reset the switch or router back to factory defaults.
do this by using a pen to press and hold the reset switch inside the small hole on the back or base of the router or switch.
You need to hold the switch in for ten seconds.
The unit will reset and you can then access the management interface using the directions I gave you above..
I want to connect my
The Fiber optic sloution requires cost of new equipmets ( Coper to Fiber converters) , Fiber cables , Fiber patch cords and labor cost as well.
How to reset linksys SR2016 router to factory
- Hold the reset button on the back panel of the Linksys router for 30 seconds. ...
- When you access the router utility to change the router settings from the default values, be sure to leave the User name field blank and enter admin in the Password field.
Frontier router
Frontier Router Login at the bottom of the Network Connections window, just below the address bar. Select Wireless Properties from the menu. Locate the Network security key field on the Security tab. You'll see your Wi-Fi network password if you click the box for Show characters.
1/28/2022 7:46:04 AM •
Linksys...
Answered
on Jan 28, 2022
