PDF
BaoFeng BF-888S ... Lights red during transmit, green when receiving a signal ... you that battery needs recharging. Alert tone will sound and Red LED will blink.
7 pages
Mine is doing same thing after 2 hrs. I tried 3 new batteries and still having problem so I hope someone has an answer as to what is causing this. Thanks.
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf But to answer your question here is what the difference between the green light and the red light are: 1. X-Band Signal Indicator—A green LED lights and blinks to indicate the presence of an X-band radar signal. The blink rate increases as the radar source gets closer. A distinct audio alert is also heard. 2. K-Band Indicator— An amber (orange) LED lights and blinks to indicate the presence of a K-band radar. The blink rate increases as the radar source gets closer. A distinct audio alert is also heard. 3. Ka-SuperWideband Signal Indicator— A yellow LED lights and blinks to indicate the presence of a Ka-SuperWideband radar signal. The blink rate increases as the radar source gets closer. A distinct audio alert is also heard. 4. Laser Signal Indicator— A red LED under L lights and blinks to indicate the presence of a laser signal. A distinct audio alert is also heard. 5. SWS Signal Indicator— When an early warning hazard or informational signal is detected, the yellow SWS LED begins to blink and the amber K-band LED lights. A distinct audio alert is also heard. 6. Power-On Indicator— A green LED under P lights to indicate power is being supplied to the unit and the unit is turned on. 7. LED Signal Strength Meter—Four LEDs give an accurate visual indication of the strength of radar or laser signals. 8. City Mode Indicator—A green LED under C lights to indicate that you selected City Mode. 9. Auto Mute Indicator— A red LED under M lights to indicate that you selected the Auto Mute feature. Please make sure you give me a rating and I hope this helps, cbinny1
