Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
A
Anonymous Posted on Jan 18, 2006
Thermostat calibration? How do I calibrate the oven thermostat?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 17, 2006
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
7901
Points
It's on page 32 of the manual for Thermador's built in convection ovens. 1. turn off the oven 2.touch and hold the start pad and then touch the bake pad 3. 0 (zero) appears in the temp digits. release all pads 4. touch bake and 0 changes in increments. max adjustment is 35 degrees F. 5. to complete change touch start for lower oven on double ovens do this: touch the roast pad instead of the bake pad continue with steps 3-5.
A
Anonymous
The method suggested here does not "calibrate" the oven thermostat, it merely adjusts the reading on the control knob. What I was looking for is a way to actually have the oven setting equal the oven temperature. The best he offered was to "call an appliance repair person." There must be a better way.
Anonymous
Level 2:
Novelist:
  • Expert 74 Answers
  • Posted on Jan 18, 2006
Anonymous
Expert
Level 2:
Novelist:
Answers
74
Questions
0
Helped
126406
Points
259
If your oven has a calibration right on the knob, you can calibrate it as follows. If it doesn't call an appliance repair person. To adjust the thermostat's calibration: 1) Remove the oven temperature knob by pulling it off its shaft. 2) Notice the current setting, then move the pointer in either direction to adjust its temperature slightly up or down. It's intentionally difficult to move the pointer; on some models, you'll have to remove a couple of screws. Figure moving it one notch will change the setting by 10 degrees F. 3) For more accurate calibration, call an appliance repairperson.
2 Related Answers
mc1bean
Mike Cairns
  • 3054 Answers
  • Posted on Oct 28, 2011
SOURCE: oven is 50 degrees out of calibration and will not
Hello, kadid
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and farther back, It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your oven, from repair to trouble shooting it. Even pictures and video's. Just scroll around and you will see tons of information to almost any question you might have on your Oven. If you go to this link and click around, I am sure you will find out so much about your oven, you will know more than the company that made it. The good thing about this link is, then you can make the decision of DIY or hiring a pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Anonymous
  • 15935 Answers
  • Posted on Nov 12, 2010
SOURCE: I have a jenn-aire oven that the oven temp is 50
You cannot to that degree of difference. You need to replace both oven sensors to remedy this. Part is very inexpensive, easily replaced and available at any appliance parts supply house. Looks like a small rod in the corner of the oven. If temp is still off then you can make a minor adjustment to the control.
You can change the 'offset' by doing this if you want: Select a bake temp above 500
Press Bake pad and hold it for 4 secs and release it
Press the number keys to get the temp difference you have in the display
Use the broil key to make it either add or subtract the amount you entered so the displayed temp will match your reading.
IF you mess up just repeat the process again as it can be done as many times as you want.
Maximum change allowed is 35 deg.
Thanks!
No temperature control on hot plate elements. Is this fixable?
ADJUST OVEN FLAME LEVEL: Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat. The reason for my free advice is GOD is good!
Dec 16, 2016 • Ovens
How to calibrate oven?
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element
Dec 01, 2016 • Ovens
I can not get the oven to come on. It is pluged in and the stove top works. The oven runs off electric and the top is both. No one can fix it and the oven does not heat up at all.
Most of the time, whn this problem occurs on ovens, it is mainly caused by the ovens thermostat. Run a test on the oven thermostat and replace it if it is faulty.
An oven thermostat is a switch that opens and closes in response to the temperature it senses. It is typically found in the control panel, where a liquid-filled temperature-sensing bulb senses and maintains the internal oven temperature by cycling heat on and off.
Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!
Access the oven thermostat, which is located in different places depending on the make and model: On freestanding ranges, access the thermostat by removing the screws that hold the back panel in place at both ends. On models with front-loading controls, remove the panel and tilt it for access. Be careful not to let the wires disconnect from their components. Some built-in models have a removable backsplash. Lift the backsplash, rest it on the cook top and remove the screws from the backsplash, which holds the rear panel. On wall ovens or eye-level ranges, access the control panel by opening the door and removing the screws that secure it. The screws may be under the exhaust hood or below the control panel. If the control panel is hinged, simply tilt it towards you. On some models both the rear and front control panels must be removed. The screws may be found on the trim and occasionally the trim must be removed.
When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced.
Adjusting the thermostat: Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration.
To remove the thermostat: Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place. To install a new thermostat, reverse the disassembly procedures, transferring the wires individually from the old unit to the new.
Hope this was helpful. Thanks for using fixya.
Thermostat light flashing and none of the oven functions will work (fan, grill, heat etc)
  1. Access the oven thermostat, which is located in different places depending on the make and model: On freestanding ranges, access the thermostat by removing the screws that hold the back panel in place at both ends.On models with front-loading controls, remove the panel and tilt it for access. Be careful not to let the wires disconnect from their components. Some built-in models have a removable back splash. Lift the backsplash, rest it on the cook top and remove the screws from the back splash, which holds the rear panel. On wall ovens or eye-level ranges, access the control panel by opening the door and removing the screws that secure it. The screws may be under the exhaust hood or below the control panel. If the control panel is hinged, simply tilt it towards you. On some models both the rear and front control panels must be removed. The screws may be found on the trim and occasionally the trim must be removed.
  2. When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced.
  3. Adjusting the thermostat: Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature. If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration. Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
  4. To remove the thermostat: Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire.
  5. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place.
  6. To install a new thermostat, reverse the disassembly procedure, transferring the wires individually from the old unit to the new.
Hope this was helpful.Thanks for using fixya.
Jan 26, 2011 • Ovens
1helpful
Bake element will not shut off at set temp.
You need to check the oven cycle relay,
  1. Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!
  2. In order to gain access to the oven cycling relay, refer to your owner's manual. Removing the back panel of the range accesses most relays, but some ranges locate the relay under the oven compartment where the utility drawer is usually located.
  3. Now you can test the relay using your VOM. First, label each wire attached to the relay and remove them from the relay terminals. Using your VOM's ohmmeter function, set the range to R x 1 and touch one test lead to the terminal marked L and the other test lead to terminal H2. There should be NO continuity. Next, test the terminals marked H1 and H2. Again, there should be NO continuity. Finally, test the S and R terminals. Continuity should exist between these two terminals. If your relay does not pass all these tests, it is defective and should be replaced.
  4. To remove the relay, undo the two screws securing it to the range and replace with the correct new relay. Refer to your wiring diagram and labeled wires to ensure that the wires are on the correct terminals. Now replace the back panel or drawer and test the oven.
Then you check the oven thermostat: When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced. Adjusting the thermostat: Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
To remove the thermostat: Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place. To install a new thermostat, reverse the disassembly procedures (Step 7 above), transferring the wires individually from the old unit to the new.
Hope this information helped you.
Oven does not work and the elements are good no f codes and the probe was change?
Hello there:
  2. Access the oven thermostat, which is located in different places depending on the make and model:
    1. On freestanding ranges, access the thermostat by removing the screws that hold the back panel in place at both ends.
    2. On models with front-loading controls, remove the panel and tilt it for access. Be careful not to let the wires disconnect from their components.
    3. Some built-in models have a removable backsplash. Lift the backsplash, rest it on the cook top and remove the screws from the backsplash, which holds the rear panel.
    4. On wall ovens or eye-level ranges, access the control panel by opening the door and removing the screws that secure it. The screws may be under the exhaust hood or below the control panel. If the control panel is hinged, simply tilt it towards you.
    5. On some models both the rear and front control panels must be removed. The screws may be found on the trim and occasionally the trim must be removed.
  3. When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced.
  4. Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
  5. If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration.
  6. Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
  7. To remove the thermostat:
    1. Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire.
    2. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place.
  8. To install a new thermostat, reverse the disassembly procedures (Step 7 above), transferring the wires individually from the old unit to the new.
1helpful
New replacement thermostat needs calibrating on my Kenmore oven
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similar thermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
Fixing thermostat on oIder Hotpoint Double Oven
Hello, there is no fixing the thermostat although some of the older thermostats could be calibrated by using a very small flat head screwdriver in the shaft of the thermostat if there is no opening for a tiny screwdriver in the shaft then it cannot be calibrated. If you have to change the thermostat contact your local parts department have the model # handy if the original is not available ask about universal oven control replacement parts. Good Luck
1helpful
Thermostat setting for bakers pride y600 oven.
Hi, those screws are for the calibration of the knob to the thermostat, so your calibration is correct. Most likely you will have to contact a servicer to check the calibration, and set you knob and plate where they will align with the actual temp again.
Hope that helps, and thank you.
Top Jenn-Air Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
