With the selector buttons find Descaling and press OK
This process takes about 35 minutes
1. Empty the water tank, drip tray and grounds container.
2. Insert tray and grounds container, refill tank with with 0.5 Lt. of
water and add descaling agent (not the pill or powder used for clean
cycle) to tank. Make sure its completely dissolved.
3. Place a container or cup under the steam wand large enough to hold 0.5 lt.
Display says Descaling and press OK
4. Press the water button
Display says Descaling in Progress
after the descaling agent is exhausted
Display says Empty Drip Tray and Spent Grounds
5 Also remove rinse and refill the water tank to Max line
6. Press the water button again
after the machine stops
7. Empty the drip tray and spent. ground container and replace
Display says Rinse Press OK
Display says Appliance Ready
In essence go to Descaling Press OK and follow the directions as they are displayed.
If you can get steam/water from your steam spout.
Fill your tank and add descale solution.
Descale according to the instruction for the unit.
After descale and rise are complete refill your water tank.
Your system should now work as normal.
Note: If you do not have a descale solution, run the above with just water. Remember to descale when you obtain a descale solution.
Check out this tip about how to
descale your Keurig coffee brewer
How
to Descale your Keurig Coffee Brewer
heatman101
