Question about DeLonghi Coffee Makers & Espresso Machines
My de longie coffee has been descaled only once in over 12 months when the descale light come on .. It has not come on since and I am sure it should be descaled now . How can I start a manual descale ?
Posted by Terry Hayes on
Phillip Hicks
  • 917 Answers
Depends on how many times you have used it, before descale light comes on. Might not be able to manual descale, read instructions. You can buy Descaler Solution from all Supermarkets, but if unit working OK, leave it for a few Months, and see what happens..
Posted on Jul 23, 2012
My keurig is not making a full and my De-scale light is on
Run 8-16 oz of vinegar through it. That will help descale the machine. As a side note, make sure to run straight water through your maker at least five or six times (until the water doesn't smell like vinegar) once it's descaled.
Feb 26, 2015 | Keurig B100 Coffee Maker
Red light showing when i go touse frother steam not consistent
For Saeco Vienna De Luxe Espresso MachineTeam De-Brewerz.com says:
1. Your coffee maker might suffer from Steam, Coffee Bolier clogging due to scale. Due to clogging you are unable to product perfect steam, temperature drop in coffee, inconsistent steam flow, inconsistent water flow etc. We strongly advise you to do regular Descaling to your coffee maker (every 200-300 cups or 2 months)
2. If your coffee maker in working condition but still light is keep on blinking means required "Descaling". Please use the food graded Delonghi or equivalent brand descaler. You can order to us @ www.De-Brewerz.com or buy online in India @ www.fabkaart.com
Still issue not resolved claim the warranty if recently purchased. If you are in India then contact us @ www.De-Brewerz.com
Oct 20, 2014 | Saeco Vienna De Luxe Espresso Machine
The descale light keeps blinking, what should I do?
The 'Descale' light that turns on indicates that it is time to de-scale the machine.
Scale - or mineral deposits- form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water.
You will need :
  • Keurig coffee maker
  • 48 oz. white distilled vinegar
  • Water
  • Large ceramic cup
  • Sink
Instructions :
  • 1 Unplug the coffee machine and remove the cup.
  • 2 Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
  • 3 Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
  • 4 Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
  • 5 Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
  • Good luck ;)
    Dec 14, 2011 | Keurig Elite B40 Coffee Maker
    How do you descale my Delonghi Magnifica?
    10.3 DESCALING Due to the continuous heating of the water used to make the coffee, over time it is normal for the tubing inside the machine to fill with lime scale. When the light starts flashing (section 12 - point 5), it is time to descale the machine. NOTE: when the light switches on, the coffee maker can still be used to prepare coffee. Proceed as follows: • Empty the tank and pour in the contents of one bottle (125 ml) of DURGOL descaler plus one liter of water. For subsequent descaling operations, descaling solution can be purchased from authorized technical service centers. Note: Make sure splashes of descaler do not fall onto surfaces sensitive to acid such as marble, limestone and granite. • place a container with a minimum capacity of 34 oz. under the cappuccino frother (Fig. 3); • turn the machine on by pressing the button (Fig. 4). • wait for the green and indicator lights to come on steady. • press and hold the button for at least 5 seconds (Fig.14). The decalcification warning light will illuminate (section 11 - point 8) to indicated the start of the descaling program (the and lights remain off to indicate that it is not possible to make coffee). • turn the steam knob half a turn counter-clockwise (Fig.5). The descaling solution will come out of the cappuccino frother and start to fill the container underneath. • the descaling program automatically performs a series of deliveries and pauses, so as to remove the lime scale deposits from inside the coffee maker. Fig.32 The two red buttons have snapped out CORRECTLY The two red buttons have not snapped out CORRECT INCORRECT 17 OPERATING INSTRUCTIONS • after around 30 minutes, when the light comes on (section 12 - point 1), turn the steam knob half a turn clockwise (Fig.6) until it stops. The machine must be rinsed so as to eliminate the residues of descaling solution from inside the machine. Proceed as follows: • remove the water tank, rinse it and fill it with clean water. • reposition the tank. • empty the collection container (located under the milk frother) that is full of liquid, and then replace it under the milk frother. • turn the steam knob half a turn counter-clockwise (Fig. 5). Hot water will come out of the milk frother and fill the container underneath. • when the tank is empty, the l ight goes off and the light comes on (section 12 - point 1). • turn the steam knob all the way clockwise (Fig. 6) and fill the water tank with clean water again. • the program of descaling is now terminated and the machine is ready to make coffee again. NOTE: if the descaling procedure is interrupted before completion, the alarm (section 12 - point 5) is not deactivated and the procedure must be started again form the beginning.
    Jul 14, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
    Not enough water making it from holding tank to dispensing cup
    your machine is "Short Cupping"
    It needs to be descaled. Even though the descale light might not be on yet, the descale light only comes on when it is in SERIOUS need of a descaling. You should descale once every 3 months.
    Fill reservoir with distilled white vinegar and leave the machine on for 4 hours (make sure to turn off the auto off option).
    after 4 hours, run the vinegar through the machine until the reservoir is empty. Refill with water and repeat twice. you will notice a difference right when you start running vinegar through.
    Apr 04, 2010 | Keurig Elite B40 Coffee Maker
    The red light for descaling won't go off after descaling
    The button to push was the steam button and hold for 5 to 10 seconds until the light goes out.
    Apr 22, 2009 | Saeco Magic De Luxe Espresso Machine
    De-scaling
    Try doing descaling with a descaling product , like the ones below:
    Urnex Cleancaf Coffee Maker Espresso Machine ...
    $9.99 - DBROTH
    Miele Coffee Machine & Steam Oven Descaling ... $20.55 - Totalvac.com
    Apr 19, 2009 | Keurig B60 Coffee Maker
    Red descale light is on
    I use distilled white vinegar, but you can use specialized coffee cleaners with this model:
    Descaling
    Descaling 11
    Descale your Tassimo machine every three months to keep it
    operating at full potential.
    Descaling products are widely available from stores selling coffeemakers and espresso
    machines. Only use a product intended for descaling. Mix the descaling product
    directly in the water container, following the instructions provided on the descaling
    packaging. Replace the water container on the machine.
    2 Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down,
    and close the brew mechanism. When the AUTO light illuminates, press and release
    the start/stop button. The brew cycle will fill the machine with descaling solution. Empty
    the cup and let the machine stand for 15 minutes.
    3 Open the brew mechanism and close it again, leaving the cleaning disc in place.
    When the AUTO light illuminates, press and release the start/stop button. When the
    machine stops running, empty the cup, and let the machine stand for 15 minutes.
    Repeat this step two more times for maximum descaling effectiveness. Discard the
    remaining descaling agent from the water container, rinse it thoroughly and refill
    with fresh, cold water.
    4 Open and close the brew mechanism again, leaving the cleaning disc in place.
    When the AUTO light illuminates, press and hold the start/stop button to flush water
    through the machine. The MANUAL light will flash. When the cup is full, release the
    start/stop button, empty the cup, and replace it on the cup stand.
    5 Repeat step 4, flushing clean water through the machine in the same manner and
    emptying the cup as it fills. To ensure that all the descaling solution is completely rinsed
    away, flush two full water containers through the machine before using it again.
    Mar 26, 2009 | Braun Tassimo Coffee Maker
    Coffee Makers & Espresso Machines Logo
    1,114 people viewed this question
    Top DeLonghi Coffee Makers & Espresso Machines Experts
    Marvin
    Marvin
    Michael Thomas
    Michael Thomas
    Paul Bade
    Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
