Hello,welcome to FixYa.
The E68 is indicating a push button is stuck, refer to this chart below for explanation and potential remedy.
The reason this is happening can be for a couple of reasons. When a button is pushed, the contact inside the control is sticking in the "closed" position, or the plastic button which activates the switch, is binding on the console and not allowed to return via the small spring which insures it does under normal conditions.
Let me know how you make out or if anything is not clear and I'll help in whatever manner I can going forward. Good luck.
Regards,
Macmarkus :)
Hey friend, thank you for allowing me to assist you!
I understand that you are getting an E68 error code on your Frigidaire Affinity dryer, it usually stands for a key (button) that is stuck closed (active). Let's try entering a "Function Test Mode" and perform the Key Test to determine which button could be the problem. To perform "Function Test Mode": Press and hold START and the CANCEL button at the same time for 10 seconds. The key that is stuck should blink. Free the key and perform the test again. If the button is free but the error code still exists, the electronic control will more than likely need to be replaced after it has been properly diagnosed by a professional. If you need help in contacting a technician you can view the manufacturer website to find available technicians in your area. Hope this is helpful. -Matt
