Garden Logo
Posted on Aug 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a parts diagram for a cav fuel injection pump. Came off david Brown tractor Model 770 A.
fred_therese
Level 2:
Sergeant:
  • Expert 332 Answers
  • Posted on Jun 13, 2015
fred_therese
Expert
Level 2:
Sergeant:
Answers
332
Questions
Helped
74037
Points
852
Go to case IH parts on line and find your tractor model and pump diagram
4 Related Answers
Phil Rivera
  • 83 Answers
  • Posted on Mar 30, 2009
SOURCE: Ignition coil for David Brown 12 volt
Bring your coil into your local auto parts store and they should be able to match it up. There is a question of "with and without a resistor", "With" is usually the right answer. Don't worry even if this is wrong it will not harm anything. So yes, coils are generic.
Anonymous
  • Posted on Jul 19, 2011
SOURCE: manual for lawn tractor
I have a problem with the transmission drive belt breaking
Anonymous
  • 6468 Answers
  • Posted on May 04, 2012
SOURCE: need diagram for replacing belt on sears garden tractor model 917 287480
the bottom of the foot rest there is a picture of the belt routing
performan992
  • 3 Answers
  • Posted on Aug 06, 2012
SOURCE: Looking for schematics for a yardman lawn tractor model 760-770
Use the MTD part finder website and get the diagrams as you are seaching for the parts.
http://www.mtdparts.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10101&catalogId=19502&langId=-1#/MTD_Merged_Data/13637-8_(1988)/Lawn/010103700-A/0101037000001
1helpful
Replaced injector pump 990 David brown original had ceased now tractor starts runs for 20-30 seconds then dies. Restarts fine but only runs for 20-30 secs. First start in morning ran for 2-3 minutes
it indicates that there is a fuel shortage problem
check the supply pump for fuel supply to the pump elements
if the fuel supply pump is part of the injector pump , there could be a blockage in the fuel line or air still in the system
of there is a good supply of fuel to the pump then contact the shop that reconditioned the pump
if you just fitted another pump without reconditioning it , then talk to an accredited diesel pump specialist shop
1helpful
2answers
I have a 1989 Case 580 backhoe tractor. I am interested in increasing the horsepower. It has a mechanical turbo. Can you help me?
Can you tell me which injection pump you have on your 580K. It could use a robert bosch or a C.A.V. Let me know I will help you. One thing you need to know, with a cav pump the engine will not have much torque rise in power. The engine is a powerhouse that runs hydraulic pumps at full throttle. This is a full throttle tractor that should run that way all time .If you are trying to back up hill at say half throttle ,it will not do it, try First gear full throttle. Remember the tractor with bucket and backhoe weight is about 16000# . I do not think adjusting the fuel delivery will help this tractor.
2helpful
2answers
Diesel injector pump CAV 55/850/9/2160 or maybe LP 55/850/9/2160. From a 3165 MF tractor. Is it compatible with 3240F938 or Lucas 40B 883517M91
it is possible that it will fit but the major problem is not if it fits-- but is it calibrated ( fuel settings)correctly for the engine
this should only be discussed with a specialist diesel pump repair shop
if it fits but is not calibrated properly , they can reset it for the engine
with diesel engines , if the calibration is out , sever engine damage will result
How to connect the fuel liunes and wherethe fuel lines connect on the fuel pump for 2004 chevy cavalier
Your Cav has Fuel Injection, therefore the electric fuel pump is inside the tank. uel injection units require much more pressure than a manual pump can deliver.
Iam looking for timing gears for my david brown 880 series tractor can you help .Thanks
go on line to google -yype in david brown engine timing gears and thefirst page is david brown tractor club
www.dbtc.co.uk
there will be similar clubs around the world
try also davidbrown parts .com/page80.html as there are images of the gears .
Where can I get a diagram of a ford 3000 cav injection pump?
Type in the serial number and brand name of the injection pump
and Google it. You will find a link that will guide you to what your looking for.
1helpful
David Brown 990 selectamatic how do I know what engine it is fitted with in order to determine which crankshaft to order
Talk to david brown parts department and quote the tractor serial number and the engine serial number and they should be able to tell you the part number for the crank that will fit that engine. . They should also be able to tell you the year and model of the engine so with the part number and the other details you should be able to source from a tractor wrecker the shaft you need.
1988 Ford Bronco fuel injection system isn't getting power to it
i had a similar problem that ended up being the fuel pump relay located in the engine compartment on the drivers side next to the air box. there will be at least 2 relays, the fuel pump one is black and brown. check that first.
Looking for a component diagram for cavs jb199
I can only find the user manual. I can also find a little commentary from another website. Perhaps the manufacturer can be of assistance. Or someone in the Cavs forum (listed at the top of the website page) can be of assistance.
http://www.cavsusa.com/
http://www.cavsusa.com/JB-199/JB199_Manual_080514.pdf
Cavs JB 199 II Premier Public Forums Karaoke Discussions Karaoke Scene...
Top Diesel Garden Experts
john h
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Diesel Garden Expert? Answer questions, earn points and help others
