Hate to tell you, but you will need to pull the carbs off again. When cleaning the float needles, check for wear on the needles. Check to make sure the tip of the needle is pointed without any grooves wore in tip and the 4 "corners" of the needle are not getting flat. Also check for wear in the needle seat where the float needle sits. The seat should be round, and with use it will wear grooves where the needle rides up and down with the float. If those parts are worn out it will not shut fuel off to the carburetor, especially on a gravity feed fuel tank. Let me know if this helps, Daniel.
