The screen is usually a replaceable part. You should always try to replace a broken part yourself first. search model name plus "repair guide" on any search engine.They will show details about about part replacement etc. in detail. There are other websites that sell all the replacement parts, one of the bigger ones is http://portatronics.com (646) 797 2838. Then for the repair itself you can venture to do it yourself, or better ask a friend who has done a similar repair before.
Thanks for using FixYa. The issue is with the failed convergence (STK) ICs which needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. There arerepair kitsavailable which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks for using FixYa. If the issue is with the failed convergence (STK) ICs which needs to be replaced then, it’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black/gray heat sink and also check theresistors as if they are short the ICs might blow again after sometime. Please check this picture: And yes you are right there arerepair kitsavailable which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks for using FixYa. The issue is with the failed convergence (STK) ICs which needs tobe replaced. It’s not a difficult job if you want to do this yourself, youshould require some basic knowledge about soldering-resoldering components. Tostart with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check theresistors as if they are short the ICs might blow again after sometime. There arerepair kitsavailable whichincludes repair instructions with the parts, if you want to do it yourself, youcan buy and repair it yourself.Please do rate thesolution if the issue is resolved or post a comment for further assistance.
