20 Most Recent Schumacher 400w Power Inverter Questions & Answers
I have the SSC-1500A battery
This unit will assume a battery voltage less than 1.5 volts means the battery is sulfated. The flashing yellow light means it has gone into 'desulfate' pulse mode using pulses of high voltage to try and convert the lead sulfate back into sulfuric acid and lead plating. It will do this for about 8 hours on the charger I have. If the voltage has not raised to a level that can can accept a normal charge it will abort the pulse mode and stop trying to charge it. You will need to unplug and replug in the charger to try again. Always check the temperature of the battery while charging it and especially if the charger is in pulse mode. Stop charging if the battery is hot. *always wear safety gear*
6/30/2014 1:29:34 AM • Schumacher 400w... • Answered on Jun 30, 2014
0answers
Lost the wall charger of my Schumacher 400w power
Ah, I see, it seems what you have is a power pack. If so it would contain a gelcell battery, probably 12 volts. If this is true, then you may charge it with any 14-16 volt wall charger. You have to make sure you observe correct voltage and correct polarity when connecting up. Also you may have to obtain and change the plug on the charger wire.
I'm assuming the battery DC output is inverted to AC and you use it to power small AC appliances.
12/15/2012 6:22:01 PM • Schumacher 400w... • Answered on Dec 15, 2012
Will not charge a battery
It's not supposed to. It changes DC to AC.
4/24/2011 8:53:39 PM • Schumacher 400w... • Answered on Apr 24, 2011
I need a replacement charger for my Schumacher
will not charger the batterys
4/24/2011 7:40:40 PM • Schumacher 400w... • Answered on Apr 24, 2011
Power out plug in's aren't making good contact.
Yes.
8/6/2009 2:25:38 PM • Schumacher 400w... • Answered on Aug 06, 2009
Need manuel
5/22/2009 8:55:19 PM • Schumacher 400w... • Answered on May 22, 2009
To recharge a Schumacher Portable Power 400w inverter, should the on/off button be on or off?
most inverter devices will charge in the off position
10/5/2018 7:22:38 AM • Schumacher... • Answered on Oct 05, 2018
Have a 2000w inverter in
With inverters and generators, the power rating is usually off by about a quarter. Watts and volt-amperes are totally different and sometimes inverter manufacturers don't tell about the difference. A basic rule of thumb is to take whatever the inverter is rated for and knock a quarter off. So, in your case it would be best to assume a maximum rating of 1500 watts. Also, inductive loads like drillers (electric motors) usually have a start-up current 3 to 8 times the rated operating current. Meaning that 100 watt driller will draw 300 watts to start up. So, if you use an electric motor rated at 700 watts, its startup load would be 2100 watts or even more and thus trigger the inverter overload switch. Hope this helps you.
12/20/2017 3:27:18 PM • Schumacher... • Answered on Dec 20, 2017
2answers
How should I hook up a 2000 watt schumacher inverter to a 12volt battery
i normally mount it under my seat run one lead straight to the positive (red) lead of battery with a 30 amp fuse using an inline fuse holder fully sealed.than the ground (black) using a ring connector to the chassis or seat mounting stud.must run positive under carpet and through fire wall using a grommet or other possible wire channels.
8/17/2014 3:29:30 AM • Schumacher... • Answered on Aug 17, 2014
0answers
I have a 750 W
Be the first to answer 5/31/2011 5:59:38 PM • Schumacher... • Posted on May 31, 2011Be the first to answer
I have a Keb 12F5 that shows E.EF external fault. How to solve it please?
It appears to be something to do with this https://www.google.com/search?q=keb+12f5+that+shows+E.EF+external+fault 7.13.1.6 External fault With Pn.04 "Ext. fault input selection", one or more digital inputs can be programmed which can trigger the error "31: ERROR! External input" (E.EF). With Pn.03 "E.EF stopping mode" , the response of the inverter to the digital input is defined. With Pn.65/ bit 1 "2: Pn.04 = E.UP https://www.keb.su/doc/Instrukciya%20F5-A_E_H%20ver.4.0%20(ang.).pdf ..
2/27/2024 6:55:25 AM • Electronics -... • Answered on Feb 27, 2024
Schumacher 400w Power Inverter Logo
14 questions posted
Top Schumacher Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Schumacher Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Schumacher Electronics - Others
Most Popular Question
lost wall charger schumacher 400w power
  • Electronics - Others
