Contact them I put a link below....I don't haveone but I was told when they called me back that they could email or fax one to you. It only took about an hour before they called me back.
can you clarify that, i am not sure what part of a basket strainer dimension you are refering to. the dimensions of a basket strainer are related to the standards of the fixtures they are installed on. It has to be designed to work on different thickness of materials; thick materials such as cast iron or marble and thin materials like stainless steal and pressed steal. I have experiensed some strainers that do not meet this and are not deep enough to fit thick materials o r do not tighten enough to handle then materials.
Question edited for correct spelling of maker 'Noen' to 'Moen'.
'Fix' as in it is leaking? Or tighten it down because it is wobbly, or something completely different?
Well, we can have a one on one seminar by the internet. I've been a pumpman for 20 years. I can share with you my experience (household pumps, suibmersible pumps, turbine pumps, gear pumps, piston pumps, dewatering pumps, mud pumps, trash pumps, mining pumps, solids handling pump, etc....) Just take your pick. Just send in your e-mail for assistance. God bless.
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
Move the lever or turn the knob. Check the stop tap under the sink. Make sure the faucet control knob or lever is tight, There is normally a removable cover that hides the screw..
Question edited for clarity, full 'make model (what it is)'.
This a Menards special. To remove handles, look for a small hole hidden from the front. They take a small Allen Key.
