20 Most Recent Bamix Mono Single-Speed Handheld Blender Questions & Answers
Whisk blade on BAMIX hand-held blender is frozen!
try to gently twist the blade up and around the shaft with a pair of pliers. I've loosened mine by pushing and pulling on the blade with the pliers. be sure to use caution so as not to wreck the blade.
3/22/2022 4:42:26 PM • Bamix Mono... • Answered on Mar 22, 2022
How to make a smoothie with my bamix handheld blender
That wonderful little stick is all you need, I sure love mine! Make sure your Mixing cup is larger than the one supplied and remember to pump up and down vigorously as you blend. Keep swirling the bottom to make sure everything got picked up and blended. You can also make powdered salt,(great for french fries) powdered sugar, Dried garlic can be made into your own freshest garlic powder (great for spaghetti and pizza). peanut butter, apple butter and Whipped cream. I also use mine to make a crazy Jello only treat that tastes like sherbet, ice cream and Jello just by blending Jello and Ice cubes. Then I chill right away after pouring it into small 3 inch glasses.
3/13/2010 9:50:23 AM • Bamix Mono... • Answered on Mar 13, 2010
I need new blades for the chopper
Try these people.. if they don't have it or can't get it I doubt anyone can. http://www.nelsonappliance.com/
1/25/2010 1:18:47 PM • Bamix Mono... • Answered on Jan 25, 2010
My handheld Bamix won't spin, but the motor is running?
There is help here, but the only way to check is to take it apart. It will be either a shear pin or some form of clutch mechanism that provides the drive from the motor to the stick and blades. https://www.google.com/search?q=Bamix+won%27t+spin%2C+but+the+motor+is+running ..
12/9/2023 8:29:00 PM • Bamix Blenders • Answered on Dec 09, 2023
Is there a BAMIX M122 wiring diagram?
Question moved from Washing Machines, to Bamix Blender. That information is not available anywhere. You will only get it from Bamix direct, IF they will let you have it. bamix® USA - Hand Blenders & Accessories - mybamix.com Ad·https://www.mybamix.com/ Upgrade Your Culinary Toolkit Today With the Swiss-Made bamix® Hand Blender. Order Now! The bamix® Immersion Blender is the Right Tool For Every Job. Lifetime Warranty. Master Your Chef Skills. Easy Healthy Recipes. Lifetime Warranty. A Milliion & 1 Uses. There is quite a network of repairers in Australia! https://bamix.com.au/stockists?type=Repairer ..
1/10/2022 11:06:51 PM • Bamix Blenders • Answered on Jan 10, 2022
Bamix De Luxe Hand Mixer - cutter guard
Instructions state to remove it, turn it clockwise, so the opposite remains true. To replace it, turn it counterclockwise.
11/26/2020 2:51:14 AM • Bamix Blenders • Answered on Nov 26, 2020
I have a Bamix and cannot remove the blade as the spindle keeps turning back on itself. This makes the appliance unusable for other uses.
Could you give more info? I have a Bamix with all the accessories so maybe able to help.:-)
7/17/2019 1:46:44 AM • Bamix Blenders • Answered on Jul 17, 2019
I have a bamix and wanted to whip cream, which blade do i use. Thank you, Jan
-Try each one that come with . So You will know which one is the best for it. Good luck Mai
1/27/2019 8:22:00 PM • Bamix Blenders • Answered on Jan 27, 2019
2answers
Hi. My bamix is not spinning. I can hear the
the coil part of the spinner is damaged,change the coil or check for whether the spinner is damaged.get to local repair shop and repair it.it will cost low.
10/3/2016 10:16:10 AM • Bamix Blenders • Answered on Oct 03, 2016
How can I find a new Bamix old model spice blender/chopper
Bar mix products made millions for world wide sales kitchen aids that change design so often they cant support a large parts division (R&D is geared to sell the next better barmix product ) if you cannot find a new old part or super ceeded shaft from the next model up or used drive shaft for sale online look for a complete used bar mix spice blender/chopper some people collect barmix units for a hobby or collection and sell double ups when you say old model if the shaft is plastic ....... its .unfix able its a heat molded construction process Vintage Bamix M122 2-Speed Hand Held Food Blender Mixer-Chopper 26283827-5cirizws2510qpn2ewibbdf3-2-0.jpg
9/16/2016 11:03:38 AM • Bamix Blenders • Answered on Sep 16, 2016
Where can I get a Fruit + Veg Holder for a Bamix V-slicer?
Ask manufacturer. they have stockists all over the world.
1/23/2015 2:07:53 AM • Bamix Blenders • Answered on Jan 23, 2015
How can I Loosen the spring blades on a Bamix mixer attachment
You are lucky. they usually fall off mine. However you can gently ease them off with small needle nosed pliers.
11/26/2014 6:01:44 PM • Bamix Blenders • Answered on Nov 26, 2014
Bamix not turning
If you haven't used it for a while tiny food particles and grease etc can harden on the shaft.Place the shaft part in a jusg of hot water for 5-10 mins then switch it on. This usually works . If not carefully remove the shaft with pliers. Put a piece of paper towel under the plier so you don't damage or scratch the shaft.
11/26/2014 6:00:49 PM • Bamix Blenders • Answered on Nov 26, 2014
Bamix Mono Single-Speed Handheld Blender Logo
Popular Tags
4 questions posted
Top Bamix Blenders Experts
Mike Cairns
Mike Cairns
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bamix Blender Expert? Answer questions, earn points and help others
View Most Popular
Bamix Blenders
  • Bamix Blenders
Most Popular Question
make smoothie bamix handheld blender
  • Blenders
