20 Most Recent
Bamix Gastro 200 Handheld Blender Questions & Answers
Oiling the shaft
go to your local hardware store and get a small can of 10 weight furnace fan motor oil,it has a spout to help direct it to the oiling point too
Removing the plastic top service plate
if the motor is running and the blade is not turning here is a rubber coupling that has probably broken.the blender will need to be pulled apart and that part will need to be replaced . it is designed to absorb sudden shocks if something hard is hit and has broken rather than burning out the motor. there are two other torx screws holding the rest of the plastic parts after the switch assy is removed by uncliping it .
My hand mixer stopped working.
Have you tried greasing it near the blade. I read in my instruction book that sometimes they seize if they aren't used often. They also suggest trying to soak the wand in a pot of hot water for a minute or two and then trying to use it in the water. Hope this helps
How can I find a new Bamix old model spice blender/chopper
Bar mix products made millions for world wide sales
kitchen aids that change design so often
they cant support a large parts division
(R&D is geared to sell the next better barmix product )
if you cannot find a new old part
or super ceeded shaft from the next model up
or used drive shaft for sale online
look for a complete used bar mix spice blender/chopper
some people collect barmix units for a hobby or collection
and sell double ups
when you say old model
if the shaft is plastic ....... its .unfix able
its a heat molded construction process
Vintage Bamix M122 2-Speed Hand Held Food Blender Mixer-Chopper
