20 Most Recent
Bosch HMV930 1000 Watts Microwave Oven Questions & Answers
Bosch dishwasher soap dispenser wont open or drain.
If your Bosch dishwasher's soap dispenser is not opening or draining properly, here are a few troubleshooting steps you can take:
- Clean the Dispenser Area: Start by inspecting the soap dispenser area for any debris, soap residue, or obstructions. Clean the dispenser thoroughly using a damp cloth and remove any buildup that may be preventing it from opening or closing properly.
- Check for Mechanical Issues: Examine the dispenser latch and mechanism for any signs of damage or wear. Ensure that the latch is engaging properly and that there are no loose or broken parts. If any components are damaged, they may need to be replaced.
- Test the Dispenser Solenoid: The soap dispenser may be controlled by a solenoid that releases it at the appropriate time during the wash cycle. Check if the solenoid is functioning correctly by performing a continuity test using a multimeter. If the solenoid is defective, it may need to be replaced.
- Verify Proper Detergent Usage: Ensure that you are using the correct type and amount of dishwasher detergent recommended for your Bosch dishwasher. Using the wrong detergent or excessive amounts can cause issues with dispenser operation. Consult your dishwasher's user manual for specific detergent recommendations.
- Check the Drainage System: A clogged drainage system can prevent the soap dispenser from draining properly. Inspect the drain hose, drain pump, and any filters for blockages. Clear any debris or obstructions you find, and ensure that the drain hose is not kinked or bent.
- Reset the Dishwasher: Try resetting your Bosch dishwasher by turning it off at the power source or unplugging it for a few minutes. This can sometimes resolve temporary issues and restore proper operation.
If the above steps do not resolve the issue, it may be necessary to consult the Bosch dishwasher's user manual for model-specific troubleshooting steps or contact Bosch customer support for further assistance. They can provide you with specific guidance tailored to your dishwasher model and help you diagnose and resolve the problem.
Need a glass door for HME9750AU
There apear to be no listings for any spares except light bulb for your model.
Not even a good second hand machine you could rob the door from, totally obsolete and time for a new one.
Model HMT84M651B/36. Why can't I set time?
On some microwave ovens (GE for one), you press a 'set time' button and rotate the knob to display the current hour then press the 'set time' button again and rotate the knob to set minutes.
Turning off demo mode on my bosch double ovens microwave 2020
try previous solution on fixya https://www.fixya.com/support/t29796790-turn_off_demo_mode_bosch_microwave_modeltry thisHold down the Start/Reset button for 3 seconds. The display will show: 0:01 2. Press the button and the Delay Start button at the same time.see mode 0 in settingshttps://www.manualslib.com/manual/767875/Bosch-Hmb5020.html?page=15
Panel light on Bosch microwave out but works fine. I'm just flying blind
I have had sometmes where bad solder connections on the display crystal stopped the display from working. May be worth a look at the connection on the main board where the display crystal is soldered to the board. If not, new main circuit board $$$$. Sharp uses a conductive rubber pad below the crystal to conduct power to the display. It is possible Bosch did something like that too. If so remove the main board, see how the crystal is connected to the board. Clean the rubber conductive pad or look for bad solder connections.
