20 Most Recent
Her Interactive Nancy Drew: The White Wolf of Icicle Creek for Windows Questions & Answers
When i play Nancy Drew:White Wolf of Icicle
You may be able to adjust this problem on the Start Menu, go to Options> Display Options> ( or something like this[I do not have this game]) and try to adjust it.
Otherwise there may be something wrong with your graphics.
Hope this helps.
Levi_xx
It never worked for me since I installed it. help please
answer:your system is not compatible or your operating system
first of all make sure the game is compatible with your system.if the box says 256 ram have at least 380 or 512 for best performance.if the box said 1.00ghz and you have .89ghz proccessor the game won't work.if you wouldn't mind would you send me the specs of your computer and the game so i can determine if the game is compatible.i only need the processor ghz and the amount of ram,video graphics and the info on the game box.if you don't know how to get this info just email me at
[email protected] will write a walkthrough for you.
Graphics do not display correctly
Has it worked before?
If so here are a few things you may need to fix / look at, since I doi not know how well you maintain the computer.
1st: Have you Defragmented your computer? If not this month, please do so ASAP.
2nd: How much free space is left on your hard drive? You need over 15% free space.
3rd: Have you cleaned out you cookies, temp Files & Temp. Internet Files?
4th: Every item you add or install anything on your computer, it starts running each time you boot up.
This eats up your limited power and processor.To see this you will need to use the CRTL/ALT/DELETE keys to open up your TASK MANAGER
On the right side you will see a TAB called START UP. Each item that is checked or ********** is running in the background.
You do not need this stuff running. Its a gift of Microsoft to make it start faster for you and is no longer a needed item since you have so much power.
Uncheck most if not all items, like MSN or YAHOO chat, Games and anything not directly related to the computer operation.
If it did run and all of the above are good then do a system restore to an date that you know it played.
GO TO: Start>>>>Accessories>>>>>System Tools>>>>System Restore
Will 83069-U18 controller work on a PS2 please?
The Nyko Core Controller 83069 is a versatile controller that is compatible with both PCs and PlayStation 3 consoles1. However, there is no specific information available about its compatibility with a PlayStation 2 (PS2). It's always a good idea to check the product's user manual or contact the manufacturer for the most accurate information.
If you have a PS3 or a PC, you should be able to use this controller. Please note that compatibility can sometimes depend on the specific model of the console and the controller's firmware version
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
Solitaire Customer Service Call 1-8O5-225-6690
We are 24 Hour Available Call Now
Well you really didn't loose them.
What happens is Hp puts in the software of a whole bunch of games where after time you have to go to their site and purchase their games.
Well there are other FREE sites to goto to find Solitaire, free cell, Spyder solitaire and such.
I also think that they meybe hidden files in Windows, but to find them you have to remove Hp games and then do a search
When the game turns on
Pokemon crystal is a Game boy color game, there for it will not run the original Game boy.
What are some good catering services?
I recomenr you Alchemiq, it is a quality caterers https://alchemiq.com/catering-nyc/. They offer gourmet appetizers, fancy food stations, upscale cocktail catering, and event design
Recommended System Requirements
Find out if you can run that game on your PC Learn about. System Requirements Lab
www.systemrequirementslab.com
you can find here the minimum and required system requirements for most of the games and the updates needed for you to download to make the games run on your system.
Update profile
Clear your question, because which types of profile update. Then i better answer given.
Thanks.
