20 Most Recent
Foxconn P9657AA-8EKRS2H (6938279104065) Motherboard Questions & Answers
Does dual core processor support Foxconn P9657AA-8EKRS2H mother board
The Foxconn P9657AA-8EKRS2H motherboard has a LGA 775 Socket. It will support Intel Core 2 Quad, Core 2 Extreme, and Core 2 Duo processors with an FSB of 1066 (800MHz). Thus is should support the dual core 775 processors. (Some Pentium 4, Pentium D and Celeron D CPUs may also be compatible with the board.) I hope this helps. Cindy Wells
1/9/2015 9:23:08 AM •
Foxconn...
Answered
on Jan 09, 2015
I have an xblade case and have 2 usb ports in the
ok, here goes
pin 1 is vcc1 (red in my case)
pin 2 is data -1 (white)
pin 3 is data +2 (green)
pin 4 is ground (Black)
I would say that pin 1 will be farthest from the single 5th pin, on my machine I havent connected anything to the 5th pin and all is well
Hope this helps, I had to figure it out the hard way and didn't do any damage by wiring wrong once or twice.
5/5/2011 6:52:20 PM •
Foxconn...
Answered
on May 05, 2011
Repeated failure to load Windows 7 HP
Hi.
Foxconn don't have this board on their list of their Windows 7 supported chipsets (which is hardly surprising), but as you state all your individual components should be perfectly OK with Windows 7 .
I suggest you flash the Bios because Foxconn had to produce a new Bios for Vista in order for that OS to run correctly.
Best of luck.
2/3/2010 7:49:49 PM •
Foxconn...
Answered
on Feb 03, 2010
HOW TO SOLVE IF PRINTER PORT IS NOT WORKING
easy buy a usb to centronics cable and problem are gone or if printer have configuration to rs32 port select this on printer or buy printer psi card for aditional printer poort the first option are the best works with all printers they have centonics connection
11/8/2009 9:23:32 AM •
Foxconn...
Answered
on Nov 08, 2009
MOTHER BOARD NOT POWERING ON
I want you to try first swap the power supply box of the PC if no change ?
go to the CPU socket remove the CPU check if any component is burnt that area if ok put a new CPU then on it .
If still behaving the same ,then the mother board is bad get a new mother board
Good luck
10/1/2009 1:08:31 PM •
Foxconn...
Answered
on Oct 01, 2009
N15141 drivers
N15141, is not a model is Australian elect, certs codes, a useless number.g41 is old intel chip set, 3.2GB max DDR memoryno model mobo told./ at all (sticker labels not told)no answers easy butfoxconnchannel.com is dead, now, 2012 it died.ended DIY support, we guess for ever, dead 10 years.drives for what OS, not told, xp,vista,w7 or w8?windows 7 sure.,. linux?drivers are a 3 way match.the MOBO and its chip sets , vast,The OEM makers, supportand the OS.all three must match, unless using USB or VIDEO cardsbut no OS told at all.The G41 can run w10 is some rare cases. (best CPU there)2010 or newer PCs or mobo are best not old.G41 is a 2008 chip.the VGA chip there is unknown not telling real mobo model,nor if using a GPU card, VGA.?they used many then. sorry can not guess mobo models me.
5/13/2022 12:52:42 PM •
Foxconn...
Answered
on May 13, 2022
Foxconn n15235 front panel jumpers
n15235 is not a model number everthat is an Australian, electrical safety compliance code. and 100% useless .foxconnchannel went dead 2012. they stopped dead DIY mobo sales, and the wiki said so too.the manuals are all lost now./ but googling finds some. but no model told, no JOY.lost the CD too , new in the box it had one, with PDF on CDlost that?, yes, ouch./or get the real foxconn, model number mobothe google that and add the word manualand bingo all jumpers told. some foxconn mobo are called contract OEM mobothe top makers of OEM PC ordered those custom and put them in their PC and the only clue is the lack of any DIY foxconn model on the board at all.that n15235 is NOT IT.learn to post photos of the mobo and all labels there.
5/13/2022 11:55:54 AM •
Foxconn...
Answered
on May 13, 2022
Pc h57m01a1-1.1-8eks3h
some boards are out of OEM PCs like gateways or the like
others were sold as DIY from foxconn direct sales.
did you lose the PC case?
or buy just a mobo , raw?
front panel pinouts you meant but failed to say just what:?
foxconn (channel) went dead. 2012
the maunuls where there, then, and now all gone. they are gone.
all is gone but the echo, (waybackmachine)
old
Intel P55 / H57 chipset
age ,2009, and lost manuals, are are not, lost 2012 year when the went dead.
no can find, me....
5/13/2022 11:50:16 AM •
Foxconn...
Answered
on May 13, 2022
Foxconn 2ABF Motherboard
you forgot the question1: need the manual ,a1, GOOGLE FOR IT2: NEED DRIVERS. WELL MAKER TOOK DOWN THERE DIY SITE.3: OR ?????????????their web site was taken down for all legacy DIY mobo .the exited the DIY businesstry buying only Asus.com mobo and only 2010 and newerTHE MOBO IS GOODIT IS Intel H61 BASED, I3 GEN2 UP, EVEN I7-2XXXRealtek ALC656 – High DefinitionHERE IS RETRO SITEhttps://theretroweb.com/hardware/motherboards/hp-foxconn-cupertino2W10 RUN ON THIS MOBO, SOUND MIGHT FAIL BUT IS EASY FIX. ASK
1/11/2022 3:11:39 PM •
Foxconn...
Answered
on Jan 11, 2022
Bios detection
DON'T OR SAY WHY YOU MUST?
99.9^% DON'T
OR BRICK LIKE MILLIONS HAVE NOW.
today is foxconn day;. and they went EOL , DYI in 2019
no PC told so is a vacuum of answers.
1/9/2022 11:41:32 PM •
Foxconn...
Answered
on Jan 09, 2022
Foxconn ml 94v-0 e253117 manual
94v-0 is PCB flame proof spec, certs.e253117, is outside USA, electrical safety certs, both uselessthen land on just ML.,useless too.the mobo I bet has a tag like these, learn to post real sticker tag labels only, not certs painted on the mobo we can not see.andWhat is N15235? (is and electric safety spec #)Often the marking N15235 is mistakenly deemed to be the model number of a mainboard or graphics card, but it's just Foxconn's ACA supplier code number which signifies that the product may be legally sold in Australia.
1/9/2022 11:40:57 PM •
Foxconn...
Answered
on Jan 09, 2022
Tean ml1 94v-0
Tean ml1 (94v-0)
94v0 is useless input, it is PCB burn rate test certs.
what is a TEAN?
ELO TOUCH Main Board LL050 TEAN ML1???? 2003? year?
ELO is where to go not now dead foxconn (DIY) only is dead.
ELO Touch panel. The original touch screen was 996-0484-00, PT1503NT.
its not a PC it is only a monitor
what matters is the PC not told by you nor what OS you run.
or ask ELO for them.
here they are, had to do reverse look-ups on PCB.
https://www.elotouch.com/support/downloads#/
1/8/2022 6:59:59 PM •
Foxconn...
Answered
on Jan 08, 2022
