20 Most Recent
L.A. Sound T475 Car Audio Amplifier Questions & Answers
My amp
It sounds like the amplifier has shorted output transistors. The clip indicator may be on because the output is equal to the rail voltage. The amp is probably going into overcurrent protection when the drive circuit engages. The amp will have to be repaired. If I'm not mistaken, this amp uses the dlogixs modules. Since the modules are not readily available, you may have to send it to an authorized service center or back to LA sound.
I have a 2002 la-sound
The fuse should be an 80amp fuse. 4 ohm subwoofers are fine. I am running this amp with 2 JBL 12" gti woofers in 1 ohm mode and this amp is goood!
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
