20 Most Recent Legacy Audio ICE LA798 Car Audio Amplifier Questions & Answers
I have a 2500 watt legacy ice amp and im tryin to
If you amp is 1 ohm stable you can run + to +, - to - on each voice coil. Wire them into the box. Run +'s to +'s on amp, - to - on amp
Other wise. If it is a 2 ohm stable amp, you run two 4 ohm dual voice coils to the amp + -, + -
If the subwoofers are 2 ohm, run + - on only one voice coil to the box for each and run + -, +- for 2 ohm load on amp or + - bridged for 1 ohm load.
I hope that makes sense.
12/4/2009 7:55:36 PM • Legacy Audio ICE... • Answered on Dec 04, 2009
No Sound No Power
It sounds like part of the power switching circuit has failed. Your options would be to have it repaired/replaced or to try to repair it yourself. If you want to try to repair it yourself, visit the following link and then respond here. You will need to have the amp powered up and you'd need a multimeter to measure the voltage at several points on the board. A good quality photo of the circuit board would be helpful.
Basic Amp Repair
3/29/2008 2:39:41 AM • Legacy Audio ICE... • Answered on Mar 29, 2008
When I select the source
Would need some more info my friend, as when was the last time that it worked.. & what changes have we made on it since it was bought ... post the same to me & in the mean while try these ...
1.) Look for an option DVD menu to turn this safety feature off for ... Go to Setup menu and perform Position
2.) Try checking the connection from your car battery to the audio device...
By the way how old is the player ..
Thanks !!
3/28/2009 12:53:00 AM • Legacy Audio Car... • Answered on Mar 28, 2009
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
4/18/2024 1:48:21 PM • Car Audio &... • Answered on Apr 18, 2024
Gathers car audio manual
How to change language to english for Honda Odyssey 2021 Gathers Radio Player
4/16/2024 4:19:39 PM • Car Audio &... • Answered on Apr 16, 2024
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
3/26/2024 3:40:48 AM • Car Audio &... • Answered on Mar 26, 2024
2answers
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
3/19/2024 7:56:21 PM • Car Audio &... • Answered on Mar 19, 2024
What demo mode the code for 4.91
'make model (what is is)' as first 3 words in all questions. https://www.google.com/search?q=demo+mode+the+code+for+4.91 ..
3/19/2024 2:42:25 AM • Car Audio &... • Answered on Mar 19, 2024
Xplore Amp 5553. How many watts RMS and impedance loads.
Unfortunately, no one knows or is telling. Companies rarely state power in RMS because Peak Power is a much more impressive. 1000 watt amp, 200 watts RMS x 2 channels at 8 ohms. Look for a sticker on the unit. https://www.google.com/search?q=Xplore+Amp+5553 ..
3/19/2024 12:23:13 AM • Car Audio &... • Answered on Mar 19, 2024
Carrozzeria serial abm760p57 RADIO ON ??
What is your question? Thank you.
2/28/2024 7:23:47 AM • Car Audio &... • Answered on Feb 28, 2024
2answers
I need the code
Your code is 1 3 6 3
2/25/2024 10:20:30 AM • Car Audio &... • Answered on Feb 25, 2024
6answers
Can't find remote wire that connects from radio to amplifier in Jebson STC-1052U
This appears to be a South African audio device. This link might work better for you are we are in North America. https://www.google.com/search?q=jebson+stc-1052u+wiring+diagram or look for the Installation Manual. ..
2/19/2024 12:33:24 AM • Car Audio &... • Answered on Feb 19, 2024
Legacy Audio ICE LA798 Car Audio Amplifier Logo
4 questions posted
Top Legacy Audio Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Legacy Audio Car Audio & Video
Most Popular Question
2500 watt legacy ice amp im tryin
  • Car Audio & Video
