20 Most Recent
Kingston 2GB PC2-5300 DDR2 Desktop Memory Questions & Answers
I have Compaque Laptop . It runs very slowly.
A computer can be slow by many reasons - viruses, bad sectors on the harddrive, lack of empty space on the harddrive and ofcource, small amounth of random access memory (RAM).
Only to mention, that the memory on the picture is not for laptops and you have written "usb", which is not memory for adding to the RAM space of the laptop.
I will assume they sent you the right kind of memory.
Installing it is easy. You will need a small x-screw driver to open a small cover on the bottom of the laptop. There re usualy 2 or 3 covers there. You may open all of them to see where is the memory connector. You may or may not already have memory there. Remove the old if there is no place for the new. To remove, pull two end latches to the side and the memory will tilt up. To insert the new, insert it the same way tilted and when the contacts are fully in the connector, press it down to lock the latches.
2261 pram
2261 pram
It's identified as 2261 pram usb device and not working
11/18/2014 1:23:34 PM •
Kingston...
Answered
on Nov 18, 2014
