Question about Kingston Computers & Internet
How do i format my kingston datatraveler 300 256gb which says is write protected
Posted by Toshaz Zac on
Terry
  • Kingston Master
  • 11,146 Answers
Try the suggestions at the following links and let us know if it works or not.
Remove write protection from kingston 64gb flash drive Storage
How to format write protected USB flash disk Solved Closed
Posted on Jan 23, 2018
5 Related Answers
Anonymous
SOURCE: How to format a pen drive?
Try HP formatting tool with administrator previliages in vista
Posted on Jan 07, 2009
Nikos Kefaleas
  • 7 Answers
SOURCE: HOW TO FORMAT A WRITE PROTECT USB DRIVE
try this tool HP USB Disk Storage Format Tool!!
Posted on Feb 25, 2009
Fixer
  • 272 Answers
SOURCE: Can't Reformat Kingston DataTraveler 2.0 USB memory stick
Use any linux bootable distro, like puppy (100 MB ) Slax ( 200 MB) or ubuntu to make a live boot, or use any pc which has linux installed can format your USB to its full capacity.
Posted on Apr 20, 2009
Traci in Texas
  • 124 Answers
SOURCE: 64GB Kingston DataTraveler won't format
Try using someone else's computer to format it. If that doesn't work .... then it sounds like the drive itself has sustained physical damage. I would contact whoever sold it to you and ask them for a Return Merchandise Authorization (if you bought it recently) because it is probably dead.
Posted on Jun 13, 2009
bronk50
Brian Sullivan
  • 27725 Answers
SOURCE: how do i remove write
click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
don
Posted on Feb 24, 2011
How to remove write protection from kingston usb drive
From the Kingston website:
DT101G2 - DataTraveler 101 G2 FAQ
Is there any security or write protection feature available for this DataTraveler? Unfortunately this unit does not have any security or write protection feature. If you receive a write protection message with this drive, check for the following:
  1. Verify that you are allowed to write to removable storage devices. There may be a security setting in the OS that disables write access to removable storage devices.
  2. Make sure you have not enabled write protection on the drive by using a third party software.
  3. If none of the above apply, the drive may be defective. Contact Kingston Technical Support for further assistance.
May 31, 2012 | Kingston DataTraveler 101 G2...
I am trying to format the 64 kingston DataTraveller usb but i cant because it is write protected
You will have to remove the write protection in order to be able to format the flash drive.To do so,
please follow the detailed instructions from the below page.
http://en.kioskea.net/faq/4214-remove-write-protection-on-pen-drive
Nov 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston datatraveler 512 MB is write protected. there is no switch.i cant format del data
Well u cannot do nothing than to kindly replace it. If u r able to get it working, it'll tell u same thing after sometime. 100%sure
Feb 07, 2010 | Kingston Technologies 512MB DataTraveler I...
My datatraveler 64gb dont formating in my
datatraveler dti.4gb ""the disk in drive E is not formatted" how to solve my problem
Dec 17, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston Datatraveler 2GB Failure
Try formatting the drive. Should be a problem with the file system.
Jul 26, 2009 | Kingston Technologies 512MB DataTraveler I...
Formating process of 2GB write-protected usb
Okay if you right click on the drive and open properties, you should see a check box that says Read Only. Make sure that that is unchecked. If it is already unchecked tell me and I will continue troubleshooting. Then attempt to format the drive again.
Ryan Frame
Creative Energy Associates Technical Center
May 02, 2009 | Kingston Technologies 512MB DataTraveler I...
Flash Disk problem
Hi asad_wouria,
Try it on another computer or try to format it. If it continues to give that message then you need to get it replaced at the reseller or with Kingston.
Kingston Tech Support
Jan 05, 2009 | Kingston Technologies 512MB DataTraveler I...
Nov 29, 2008 | Kingston Technologies 512MB DataTraveler I...
I cannot format my kingston datatraveler it says its protected
hello evelymont i found a solution to our problem!!try to download HP USB Disk Storage Format Tool and try to formta the flash stick to fat32 file system!!And after that you're ready to store any file you want unless you put them in a folder first because of the fat32 file system and not saving them on the root for exaple if you want to store an avi file at E: where E: is your kingston usb data traveler save the avi like this e:/name of the folder/avi file, and not in the root e:/avi file!!
that 's it !!congrats for your buy!!
Nov 21, 2008 | Kingston Technologies 512MB DataTraveler I...
Computers & Internet Logo
73 people viewed this question
Top Kingston Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Mike
Harish  Ramaiah
Harish Ramaiah
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
