20 Most Recent EXPANSYS iTour 20 Questions & Answers
Problem charging itour-20
My Lenovo computer's charging pin is broken. How do fix ?
12/8/2013 7:49:53 PM • EXPANSYS iTour... • Answered on Dec 08, 2013
0answers
Vocalizer 3 output checked cables and swapped out. 1300 watt power adaptor lights up. sound indicator light is on but no sound. tried mono and stereo. power adaptor problem?
If the display is working, you have audio. Check your amplifier. 1300Watt adaptor ... This unit draws a very low power and that is not needed.
4/24/2024 7:18:55 AM • Audio Players &... • Answered Yesterday
How do I change to degree mode on my porpo YH-2000
  1. Power Off: Turn off the device.
  2. Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
  3. Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
  4. Power Off Again: Turn off the device once more.
  5. Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
  6. Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
4/20/2024 8:57:52 PM • Audio Players &... • Answered on Apr 20, 2024
Panasonic SA-PM250 CD stereo system. Tune dab radio sa pm250?
this model SA rather than SC seems to be a Middle East model. The SC version doesn't have DAB. https://www.google.com/search?q=panasonic+sa-pm250+instruction+manual ..
4/20/2024 5:59:04 PM • Audio Players &... • Answered on Apr 20, 2024
Setting time on fmdott085 V398
All questions need clear 'make model (what it is)' first 3 words. https://www.google.com/search?q=fmdott085+V398 ..
4/17/2024 4:54:26 PM • Audio Players &... • Answered on Apr 17, 2024
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS. Question moved from Cars and Trucks category. Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries. How long is the warranty on AfterShokz? While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase. Jan 11, 2019
How To File A Warranty Claim For Your SHOKZ Headphones
https://www.google.com/search?q=Openfit+Shokz+battery+replacement ..
4/16/2024 4:58:24 PM • Audio Players &... • Answered on Apr 16, 2024
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first. But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
4/16/2024 5:57:29 AM • Audio Players &... • Answered on Apr 16, 2024
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
4/10/2024 6:11:44 AM • Audio Players &... • Answered on Apr 10, 2024
Zenith Allegro console stylus
I have the same model with the 8 track player, original manual, and original receipt dated 1975.
4/9/2024 1:32:47 PM • Audio Players &... • Answered on Apr 09, 2024
VIBE SOUND USB Turntable Model VS-2001-USBT. Where can I download drivers and application for it please?
Probably nowhere as this is an Amazon / eBay special so made in China. You should be able to go to Windows Settings, - Hardware and tell Winderz to find a compatible driver. https://www.google.com/search?q=VIBE+SOUND+USB+Turntable+Model+VS-2001-USBT+drivers ..
3/31/2024 1:46:10 AM • Audio Players &... • Answered on Mar 31, 2024
I'm looking for a manual to my IQ VOICE ORGANIZER
Hi I have a manual (and an IQ Voice organizer that I'm trying to sell). I would happily send you a pdf file of the manual if you contact me. Robert
3/30/2024 1:52:26 PM • Audio Players &... • Answered on Mar 30, 2024
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour. Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min. How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
3/26/2024 3:32:23 AM • Audio Players &... • Answered on Mar 26, 2024
Vintage Audiosonic CR-06PL Digital Alarm Clock AM/FM. After pressing SET button, wait for blink, then HOUR button does not change hour time???
Questions edited for clarity, full 'make model (what it is)'.Spray the buttons with Electrical Switch Cleaning Fluid Spray. It is an old unit and the contacts are probably dry.https://www.google.com/search?q=CR-06PL..
3/26/2024 2:55:25 AM • Audio Players &... • Answered on Mar 26, 2024
BLACKWEB BWA15HO110 Bluetooth Sound Bar. Everything seems in order with my Blackweb BWAHO110, but I get no sound on my headphone connection.
Blackweb is a Walmart brand made in China at the lowest price point. When they fail, you return them to Walmart for warranty replacement and explain you can't find the receipt. The will give you a store credit. Or you just buy a new one. There are some ideas here https://www.google.com/search?q=Blackweb+BWA15HO1O+but+get+no+sound ..
3/24/2024 1:13:16 AM • Audio Players &... • Answered on Mar 24, 2024
2answers
I can not stop alarm on my caixing cx 868 clock, who can help me
To stop the alarm you have to disable ((all)) the alarms. In (cx-808) you can set 8 alarms; so you have to press "alarm" , then "modify" 8 times. (on the right cornor shows the number of the alarms.)
3/17/2024 3:43:45 AM • Audio Players &... • Answered on Mar 17, 2024
What connections does Harbinger HX 121M stage monitor speaker have please?
Question edited for clarity, 'make model (what it is)'. The images show the rear connections. It looks like 2 x 1/2" jacks and a multi-pin connector for a sound mixer. I have never heard this term before? Passive stage monitor. Uses speakon connection. It is this
Speakon connector
Wikipedia https://en.wikipedia.org > wiki > Speakon_connector Speakon connectors arrange their contacts in two concentric rings, with the inner contacts named +1, +2, etc. and the outer contacts connectors (in the four- ... The company has disowned it! https://harbingerproaudio.com/manuals/
Harbinger HX121M 12" Stage Monitor
Musician's Friend https://www.musiciansfriend.com > pro-audio > harbinge... 12" loudspeaker featuring a 2.5" high-temperature, precision edge-wound polyamide voice coil and an 80 oz. vented magnet structure.
Harbinger HX 121m Passive monitor
Reverb https://reverb.com > Pro Audio > Speakers > Harbinger Passive stage monitor. Uses speakon connection. ..
3/13/2024 11:12:51 PM • Audio Players &... • Answered on Mar 13, 2024
EXPANSYS iTour 20 Logo
Popular Tags
2 questions posted
Popular Products
Top EXPANSYS Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you an EXPANSYS Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • EXPANSYS Audio Players & Recorders
Most Popular Question
problem charging itour 20
  • Audio Players & Recorders
