20 Most Recent
Trekstor DataStation maxi m.u SATA 3.5" 500GB portable hard drive black 500 GB USB 2.0 Questions & Answers
Driver
no detecta mi disco
3/7/2014 9:45:39 AM •
Trekstor...
Answered
on Mar 07, 2014
Goggle Chrome has stopped working
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledimak
To create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options or
click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in google.chrome) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search providers you
have if dont need any of them you can disable or remove them
you will see all of your internet connection details
or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection
hope this helps
e sure its enabledPci device arrows key scroll to nstalled
11/10/2012 7:35:28 AM •
Trekstor...
Answered
on Nov 10, 2012
The HD start with blincking
Sorry, what you hear is the so-called click of death - the reading head is no longer capable of reading the data on the disk. This in unfixable and all the data on the disk is lost.
7/15/2012 11:44:09 AM •
Trekstor...
Answered
on Jul 15, 2012
My computer does not reconize my Trekstor
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red xright click to reinstall drivers or if you can see your usb but its not workingports(com&lpt)right click update driver sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seatedif this fails to fix the problem you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap hope this helps
10/4/2011 1:31:18 AM •
Trekstor...
Answered
on Oct 04, 2011
Need software because my computer
Improve the Fixya.com experience for everyone by voting!Click on the following link for the official Trekstor DataStation Maxi mu site:
Trekstar DataStation
If that official site doesn't provide you with the required driver, continue reading.
Click on the following link for the largest FREE driver database on the internet.
Driver DownloadAll the best,
Ben
7/15/2011 10:26:08 PM •
Trekstor...
Answered
on Jul 15, 2011
Trekstor datastation maxim.u 5oo bg
Yes, there may be ways
you can try put hard drive in the ziplock bag and put it in the freezer and wait for an hour. Take it out and try it. If it works, try to move your data and quickly as you can. It worked for me before.
If disk contains very important data, and you have tried the above step but didn't work, you may want to spend $49.00 for the recovery software. This software works for me more than 90% of the time (you don't have to spend more 2K to send your disk to professional data recovery stores). Here is the link. I have used their product before and it worked, you can call them for support too after purchase the product.
http://www.stellarinfo.com/disk-recovery.htm
No one can guarantee 100% that your hard drive can be restored including my recommendation . It really depends on bad the damage to your disk is. You just have to take a chance. Good luck. I hope you don't reject my solution.
Thanks
5/20/2011 3:41:12 AM •
Trekstor...
Answered
on May 20, 2011
