20 Most Recent Trekstor DataStation maxi y.uh 400 GB USB Hard Drive Questions & Answers
reconnect your hard drive data cable and power cable then try again.
Trekstor... | Answered on Oct 09, 2008
The clicking sound you hear is unfortunately the death rattle of a hard drive. The sound is a regular click, click, click. This is because the heads of the drive can no longer find or read the sync track on the drive and usually means all the data on the drive is unrecoverable by external means. Hard drive labs can recover data from these disk failures but it requires them to dismantle the drive and that is usually a very expensive upwards of several hunderd dollars depending upon the amount of data recovered. You can purchase a replacement drive for the case and install it yourself if youare brave enough, for less than the cost of the complete package if you are good with a screwdriver.
Trekstor... | Answered on Sep 08, 2007
Seagate requires both a model number and serial number to check warranty status. Once located you can check the warranty here:
http://support.seagate.com/customer/en-us/warranty_validation.jsp
Trekstor... | Answered on Jun 03, 2013
if you are referring to a corrupted usb drive
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
If you need more help with this post a reply
hope this helps you
Trekstor... | Answered on Jun 14, 2012
click start all programs accessories open windows explorer navigate to your photos
right click on the photo's select copy navigate back to the usb drive right click select paste or select the top photo hold the mouse cursor then select the bottom photo then drag the photos to your usb drive then drop them
or if you are downloading photos from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply
hope it helps you
Trekstor... | Answered on Apr 13, 2012
abdiasdad74 I know the post is 8 years old and no one might read it, but his fix actually worked - no joke. I tried the fix on 2 laptops and when I did what he said, it worked. cool :)
Trekstor... | Answered on Sep 27, 2017
OK hello I'm new to the tech support any way how much memory on the Hard drive and much is left on the external drive it may ask you to merge to tell you you need room for all files and that you may have almost reached the compasity on the drive
Trekstor... | Answered on Mar 12, 2017
it might be that the external drive has failed . have had 3 so far that did.
Trekstor... | Answered on Jan 24, 2015
You cant. If your device was supported by windows 98, its a dinosaur. There would not be windows 7 drivers written for a device so old. If you can remove the hard drive from the case it is in and acquire an IDE to usb cable with a power pack to power up the drive you can read the drive that way, assuming the hard drive was formatted NTFS.
Trekstor... | Answered on May 04, 2014
The sound you are hearing is known as the click of death. The hard drive is no longer any good.
Trekstor... | Answered on Mar 22, 2014
it is difficult to recover it from that partition..use this software
"Recover My Files" if it is recover then ok otherwise use "Virtual Lab"
if it is not again recoverable then noway to recover. after all efforts one thing u can do is to quick format it and then try recover my files to recover from fast formated drive....but chances r very less something like wallpapers and songs can be recover.
Good Luck.
Hope the files will recover
Trekstor... | Answered on Jan 13, 2014
Trekstor DataStation maxi y.uh 400 GB USB Hard Drive Logo
2 questions posted
Top Trekstor Computers & Internet Experts
Ekse
Alun Cox
vojvodabudva
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
DataStation Trekstor
  • DataStation Trekstor
Most Popular Question
slave hard drive not responding
  • Computers & Internet
