20 Most Recent
Uniden CEZA1998 Phone Questions & Answers
My phone had no dial
I advice you follow the below link to troubleshoot what the likely problem could be.
http://www.ehow.com/print/how_2281493_no-dial-tone-phone-line.html
Type the above on your web browser and see the information therein.
Also you can reset the your phone by placing the phone on the jack while the jack is connected to the ac outlet, power on the phone, while the phone is loading, pull the plug away or simply remove plug of the jack from the ac outlet, this will help reset your phone and fix abnormality.
Take care.
Q.1 II dropped my land line phone in the sink.
Take the battery out & put the phone into a bag of rice for at least a day. The rice acts like a desiccant and will draw the moisture from the phone. If it isn't already fried, this might work.
Can I add another uniden hand set to a uniden D1680 series
The Uniden D-1680 system can have up to 12 handsets registered to the base. (The phone system was sold in bundles with 0 to 11 accessory handsets.) However, this cordless phone system has been discontinued. I can only find used DCX160 handsets (the compatible accessory handset) on Amazon and E-bay.
I hope this helps.
Sync 2 versions of Uniden Dect 6.0 to work off the same base.
Yes, you can join an older and a newer version of Uniden Dect 6.0 cordless phones to work off the same base. Here are the steps to sync them:
- Disconnect the power cord from the base of both phones.
- Take the battery out of each handset.
- Wait for a few minutes.
- Reconnect the power cord to the base of the newer version phone and insert its battery.
- Wait for the phone to register on the base, which should take a few seconds.
- Once the newer phone has registered, repeat steps 4 and 5 with the older version phone.
- The older version phone should now register on the same base.
- Test the phones to make sure they are working properly.
If for some reason the phones do not register on the same base, refer to the instruction manual that came with the newer version phone for further troubleshooting steps.
A uniden phone DECT 6.0. how do i turn on call waiting
Talk to your telephone service provider. There will be a fee.
(Uniden landline phones can make or receive calls; some models have a answering system. Most current models can even check if you have messages on the telephone provider's voice mail. (Sometimes, they'll give spurious voice mail information.) However, they don't have any built-in way of seeing any data (another call) from the telephone provider when the phone is in use.)
