20 Most Recent Peavey 1808-4 SPS BW Car Speaker Questions & Answers
My peavey 218 subs are crarking or sound
Hello Sir, Hi, distorted sound can be caused by several factors, one would be that the source, overdrives the power amps. You need to lessen the signal, if the source has a volume control set it to half. Another is the power amp itself is defective, The likely culprit it the Integrated power amp. this should be checked by a technician. and lastly the loudspeakers, to test just simply swap the other channel driver unit to the questionable one. check If the sound returns to normal. Several factors also are low voltage supply, leaking capacitors. there are no user serviceable parts here.
8/13/2010 7:06:57 AM • Peavey 1808-4... • Answered on Aug 13, 2010
Peavey pa 120
No It wont, is this a new amp you installing or is it already been installed and was working?
2/18/2014 7:16:34 AM • Peavey Car Audio... • Answered on Feb 18, 2014
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
4/18/2024 1:48:21 PM • Car Audio &... • Answered on Apr 18, 2024
Gathers car audio manual
How to change language to english for Honda Odyssey 2021 Gathers Radio Player
4/16/2024 4:19:39 PM • Car Audio &... • Answered on Apr 16, 2024
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
3/26/2024 3:40:48 AM • Car Audio &... • Answered on Mar 26, 2024
2answers
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
3/19/2024 7:56:21 PM • Car Audio &... • Answered on Mar 19, 2024
What demo mode the code for 4.91
'make model (what is is)' as first 3 words in all questions. https://www.google.com/search?q=demo+mode+the+code+for+4.91 ..
3/19/2024 2:42:25 AM • Car Audio &... • Answered on Mar 19, 2024
Xplore Amp 5553. How many watts RMS and impedance loads.
Unfortunately, no one knows or is telling. Companies rarely state power in RMS because Peak Power is a much more impressive. 1000 watt amp, 200 watts RMS x 2 channels at 8 ohms. Look for a sticker on the unit. https://www.google.com/search?q=Xplore+Amp+5553 ..
3/19/2024 12:23:13 AM • Car Audio &... • Answered on Mar 19, 2024
Carrozzeria serial abm760p57 RADIO ON ??
What is your question? Thank you.
2/28/2024 7:23:47 AM • Car Audio &... • Answered on Feb 28, 2024
2answers
I need the code
Your code is 1 3 6 3
2/25/2024 10:20:30 AM • Car Audio &... • Answered on Feb 25, 2024
6answers
Can't find remote wire that connects from radio to amplifier in Jebson STC-1052U
This appears to be a South African audio device. This link might work better for you are we are in North America. https://www.google.com/search?q=jebson+stc-1052u+wiring+diagram or look for the Installation Manual. ..
2/19/2024 12:33:24 AM • Car Audio &... • Answered on Feb 19, 2024
My radio has a periodic beeping coming through speaker when radio is on
'year make model' of the vehicle is needed in questions like this please? Modern vehicle radios are controlled by the Body control Module (BCM) and are used for broadcasting warning beeps and indicator clickers. The beeps an be as innocuous as "do you know your radio is still on"? It can also be caused by your cellphone pinging local transmitters and receiving a confirmation back, or checking in for emails.
What's that beeping? - noise beeps sounds
Ask MetaFilter https://ask.metafilter.com > Whats-that-beeping Jun 9, 2005 - What's that beeping sound I hear everywhere? It starts with one long beep, then 6-8 short staccato beeps.
Car Radio Beeping: Causes & Solutions
JustAnswer https://www.justanswer.com > Mercedes Repair Aug 26, 2010 - What causes a beeping noise to come over the radio speakers? How can it be made to stop? - Answered by a verified Mercedes Mechanic. 1 answer · Top answer: Chat Conversation Started Pete : Hello,I will be glad to try and assist you with this,Welcome ... Missing: periodic ‎' Show results with: periodic
Why is my speaker repeating a single sound of a busy ...
iFixit https://www.ifixit.com > Answers > View > Why+is+m... Apr 6, 2019 - My speaker has suddenly began making a single sound every few seconds which sounds like a single busy signal on a phone. I have read the manual, ... 11 answers · Top answer: It's low on battery. Plug it in!
2015 silverado speaker beeping issue. - GMC Truck Forum
gmfullsize.com https://www.gmfullsize.com > ... > Audio & Electronics Dec 30, 2015 - Sounds like a bad radio since it has moved on its own. Probably set a code for that speaker unplugged too. haha. ibanender said: If it didn't ... ..
2/16/2024 8:10:28 PM • Car Audio &... • Answered on Feb 16, 2024
2003 Holden Astra. Can you please tell me how to enter the radio code? The code comes up on the radio but no matter what number I press it doesn't show up. What am I not doing?
Codes are never displayed on the radio, so not sure what you are reading? There are three ways to get the radio code. https://www.fixya.com/support/r29874205-need_vehicle_radio_code
[HELP] Need radio code for 2003 Holden Astra - Austech
austech.info https://www.austech.info > showthread.php > 113459-... Jun 2, 2018 - 1. Switch on ignition. 2. Switch on the radio, if turned off. 3. The display shows 'CODE'. 4. Press and hold AS button 8, until a [HELP] Need radio code for 2002 Holden Astra Oct 23, 2014 Radio code needed for 2003 holden astra Feb 28, 2017 Code for Holden Astra Radio... PLZZ Nov 27, 2014 Holden astra radio code May 17, 2018 More results from www.austech.info
how to enter radio code - Holden Technical Talk - Fastlane
fastlane.com.au https://fastlane.com.au > forum > postst26977_how-to... Say your code is 4567. You press the AS button until your hear a beep, then press the no. 1 button 4 times, the no. 2 button 5 times, the ...
How do you input radio code for Holden astra?
Answers https://www.answers.com > Auto > Auto Parts Oct 26, 2022 - Press the AS button and hold depressed while turning the radio on. (after 3 secs you should hear a beep. Release the AS button. The display ... ..
2/16/2024 6:43:37 PM • Car Audio &... • Answered on Feb 16, 2024
Ford KA - Radio.CD No Power
Yes
2/16/2024 5:15:42 PM • Car Audio &... • Answered on Feb 16, 2024
Peavey 1808-4 SPS BW Car Speaker Logo
1 questions posted
Top Peavey Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Peavey Car Audio & Video
Most Popular Question
peavey 218 subs crarking or sound
  • Car Audio & Video
