20 Most Recent Ricoh Aficio CL7100 Printer Questions & Answers
2answers
Pages printing with a gray background
could be waste toner in printer inside the printer it may need a clean.
4/28/2015 1:12:42 AM • Ricoh Aficio... • Answered on Apr 28, 2015
0answers
What is replace color cpu toner?
Could the message have been "Replace color PCU (Type A)"? In that case, you need to replace all three color photoconductor units (order Printer Maintenance Kit Type 7100A).
I do not know of any Replace CPU error messages. I hope this helps.
8/18/2010 11:54:28 PM • Ricoh Aficio... • Answered on Aug 18, 2010
My Ricoh cl7100 was making a clicking noise, after
The 7100 fusers have a circuit that lets the machine a new fuser has been installed.
12/5/2009 3:15:53 PM • Ricoh Aficio... • Answered on Dec 05, 2009
When I try to print,
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
10/22/2009 10:46:00 PM • Ricoh Aficio... • Answered on Oct 22, 2009
PCU Replacement
You are more right than you know, the reason for the kit is for the reasons you said. When you change the kit all 3 colors are new and thereby not 3 service calls and 1 upset customer.
The kit is far cheaper and keep any "good PCUs" in the original package.
The black PCU is the most important one. Buying the different maint. kits saves $$$ as opposed to peicemeal.
You can put one color PCU in at a time if you wish.
-Carl, please let me know if this helps.
6/26/2009 8:16:07 PM • Ricoh Aficio... • Answered on Jun 26, 2009
My nasuatec dsc 435 displays sc 440-02.I don't know what to do
That code is color drum motor lock (cmy). 440-1 is for black. Pull each drum unit out and look at the drum surface if one is not turning good it will have toner all over it. Could be that the drum is full of waste toner, but usually it is a backed up waste toner auger system. If that machine uses a fuser oil the oil has leaked down into the waste toner auger system and clogged it up.
6/22/2009 12:30:51 AM • Ricoh Aficio... • Answered on Jun 22, 2009
How to get borderless printing on a CL7100
Laser printers are unable to print all the way to the edges of the paper because of the excess toner dust that will fall off into the printer unit. The only way to get true full bleed laser prints is to use a larger paper size and then cut the edges off.
6/17/2009 10:24:52 PM • Ricoh Aficio... • Answered on Jun 17, 2009
Doesn't go past warmup.
you need check:
1) there are two fuses in the fuser unit, big possible one of them broken. change fuse if you can, should be fixed.
2) if check (use meter) all fuse good, so the heat lamp damaged,
you may change it also can fix it,
fuser unit maybe expansive.
hope hep you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
5/30/2009 11:23:54 PM • Ricoh Aficio... • Answered on May 30, 2009
CL7100 error message sc 440-2 Power off and On.
hello, you problem is a color(cmy) pcu motor lock, the motor is damage or exist a mechanical problem whit the pcu's
5/1/2009 1:39:34 AM • Ricoh Aficio... • Answered on May 01, 2009
Ricoh CL7100 - Toner Cartridge Error
Not one answer for this problem. It could be the tube going from toner cart to developer unit is clogged or kinked. It could be the dev unit. Get a toner vac and remove toner and black cap and spring and using the round hose end create seal and vac the tube. The part that goes into the toner cart has hole on the very end, it might have broke off (look at another color to verify). The worst case is the toner attraction pump has failed. One fix is shake the toner and reinstall.
3/11/2009 1:44:44 AM • Ricoh Aficio... • Answered on Mar 11, 2009
Printing red stripe
Replace the magenta photoconductor.
3/11/2009 1:24:16 AM • Ricoh Aficio... • Answered on Mar 11, 2009
At start-up printer codes out a sc541 turn off then on
It's a fuser error. Fuser may need replacing, and fuser codes can only be reset by a technician, to prevent further damage
2/26/2009 4:42:45 AM • Ricoh Aficio... • Answered on Feb 26, 2009
Ricoh CL7100 Error code SC391-4
Reseat the cyan PCU .
2/26/2008 12:21:57 AM • Ricoh Aficio... • Answered on Feb 26, 2008
RICOH Aficio MP W2401 FUNCTIONAL PROBLEM SC 401
Ricoh Aficio 240W Plotter Error Code SC 401-00
Copytechnet https://www.copytechnet.com > forums > 108927-rico... May 4, 2016 - On old Ricoh Aficio's SC401 used to be a Transfer error, but on the 240 its ID Sensor, could be dirty, could be old Dev, could be a loose ... Ricoh MP2352 SC401- Strange problem Jul 28, 2021 Error Code SC-401 Sep 12, 2014 ricoh mp 3352 - error sc401 Dec 11, 2020 Ricoh mp 2851 SC 401 Jul 11, 2017 More results from www.copytechnet.com
Error Codes > Ricoh > MP2553 > Code SC401
Printcopy.info https://printcopy.info > code=SC401 Code: SC401 · Description: Transfer positive electrode current error A transfer roller current leak signal is detected. · Causes: • High voltage supply board set ... Missing: W2401 ‎' Show results with: W2401
Error Codes > Ricoh > Aficio 2090 > Code SC401
Printcopy.info https://printcopy.info > code=SC401 Code: SC401 · Description: Transfer roller open error · Causes: • Transfer power pack defective • Poor connection between the transfer current terminal and the ...
2/15/2024 7:20:12 PM • Ricoh Aficio... • Answered on Feb 15, 2024
Hi, I have Ricoh Aficio MP c2800, Machine say toner undetectable all four when i check system status and yellow, cyan is not show up on copies at all
If your Ricoh Aficio MP C2800 is showing "toner undetectable" messages for all four toner cartridges and the yellow and cyan colors are not showing up in copies, there may be several potential causes for this issue. Here are some troubleshooting steps to help you resolve the problem:
  1. Check Toner Cartridges: Ensure that all four toner cartridges are correctly installed and securely seated in their respective slots. Make sure there are no protective seals or tapes left on the cartridges.
  2. Shake Toner Cartridges: Sometimes, toner inside the cartridges can settle or clump, leading to detection issues. Gently shake each toner cartridge side to side to redistribute the toner evenly.
  3. Replace Toner Cartridges: If the toner cartridges are old, empty, or expired, replace them with new, genuine Ricoh toner cartridges.
  4. Clean Contacts: Dust or debris on the toner cartridge contacts can interfere with communication. Use a soft, lint-free cloth to clean the electrical contacts on both the toner cartridges and inside the printer.
  5. Check Developer Unit: The developer unit in the printer plays a crucial role in toner development and transfer. Ensure that the developer unit is clean and free from any obstructions.
  6. Perform a Firmware Update: Check if there are any firmware updates available for your Ricoh MP C2800 printer. Updating the firmware might address known issues and improve printer performance.
  7. Reset the Printer: Power off the printer, unplug it from the power source, wait for a few minutes, and then plug it back in. Power the printer on to see if the issue resolves.
  8. Check Toner Detection Sensors: The printer uses sensors to detect the presence of toner cartridges. Verify that these sensors are functioning correctly and not blocked by any debris.
  9. Perform a Factory Reset: As a last resort, you can try performing a factory reset on the printer. However, be aware that this will reset all settings to their defaults, and any custom configurations will be lost
8/6/2023 12:35:36 PM • Ricoh Aficio... • Answered on Aug 06, 2023
Ricoh Aficio. How I clear SC390 code? Print is clear, after 10 copies SC390 code is coming. How do I solve this problem please?
Question edited tor a lot more clarity and add MAKER, but NO MODEL NUMBER! All questions need full make and model.
Ricoh Aficio 200 - Error Code: SC390
PrintCopy .info https://printcopy.info > code=SC390 Code: SC390; Description: TD sensor error 1. The TD sensor outputs less than 0.5V, 20 s after the TD sensor initial setting has been performed. Missing: cod ‎' Must include: cod
SOLVED: How fix sc390 cod of ricoh
Fixya https://www.fixya.com > ... > Ricoh The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that ...
Error Code sc 390
Copytechnet https://www.copytechnet.com > 56632-sc-390-a Sep 24, 2011 - I've got an Aficio 1018 that's generating sc390 after every 10 copies. I recently fitted new drum, cleaning blade and developer and changed ... Missing: cod ‎' Must include: cod
RICOH Error Code List - mtechsinfo.com
mtechsinfo.com http://www.mtechsinfo.com > files > Ricoh Erro... PDF SC-390-2. Toner density sensor error. SC-391. Developer bias problem or FU103 on Aficio 550/650 Image storage address error. Aficio 551, 551P, 700, 700P. 14 pages
5/9/2023 3:30:03 PM • Ricoh Aficio... • Answered on May 09, 2023
Ricoh Aficio CL7100 Printer Logo
Popular Tags
21 questions posted
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Aficio Ricoh
  • Aficio Ricoh
Most Popular Question
ricoh cl7100 making clicking noise
  • Office Equipment & Supplies
