20 Most Recent EliteGroup C51GM-M Motherboard Questions & Answers
0answers
COMPAQ USB DRIVERS
try some of these
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html
http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html
http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Install a USB 2.0 host controller driver
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
this will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
also at cnet
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
you might have to try a few times to get it right
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivers
http://www.downloadcollection.com/device_doctor.htm
Device Doctor is a freeware Windows application that scans your computer hardware and checks to see if there are new driver updates available for your devices. It also locates drivers for Unidentified Devices in the Windows Device Manager. This tool was designed to be very simple and easy to use
http://www.innovative-sol.com/drivermax/
free program, paid update available
hope this helps
11/7/2012 5:56:58 AM • EliteGroup... • Answered on Nov 07, 2012
C51gm-m esc motherboard need divers for windows 7
if your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7 hope this helps
http://windows.microsoft.com/en-AU/windows7/products/system-requirements
3/28/2012 11:16:05 PM • EliteGroup... • Answered on Mar 28, 2012
I have a c51gm-m Motherboard
Hi, you can download a manual here:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=9&detailid=653
Here is some more info:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=653&CategoryID=1&MenuID=21&LanID=0
I think one of the ram modules is defect.
Set the bios setting to auto for the ram and let it handle it itself.
It has to work together with the cpu. Maybe the cpu does not
supports 800 mhz.
Read all about that in the manual.
9/2/2011 9:58:16 AM • EliteGroup... • Answered on Sep 02, 2011
Realtek ALC655 · AC97 Audio Codec
The audio codec is the sound driver software for the motherboard.
Click on the link provided;
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?CategoryID=1&Typeid=35&detailid=653&DetailName=Driver&DetailDesc=C51GM-M(V1.0)&MenuID=39&LanID=0
Scroll down to Sound: RealTek Codec Sound on board driver.
Create a folder on your desktop & name it RealTek. Download the file named: realtek.zip into the RealTek folder. When finished open the folder & uncompress the .zip file. You may need the program WinZip to uncompress the file. If you need WinZip you can download the trial version for free at this next link;
http://download.cnet.com/WinZip/3000-2250_4-10003164.html
Uncompress the file into your RealTek folder. Open the folder & find the setup.exe file & run it.
If this fails to install double check your bios settings. Use the manual to help you. Make sure the bios setting for AC97 is set to [Enable] or to [Auto]. Failure to set this bios feature will cause windows to prompt you for the codec software.
You can post here if you still have problems.
Thank you for using Fixya
Mike
6/24/2009 4:11:58 AM • EliteGroup... • Answered on Jun 24, 2009
Hot power supply possibly damaged motherboard
Welcome to FIXYA
As what i can tell sounds like the motherboard might of got damaged when you let the power supply over heat
sorry thats what i think
have a good day :)
7/15/2008 3:37:38 PM • EliteGroup... • Answered on Jul 15, 2008
2answers
Ecs 671t m3
The ECS website.
10/19/2018 1:20:10 PM • EliteGroup... • Answered on Oct 19, 2018
What is the basic code for html code for
HTML Background Code This article provides HTML background code - code for setting the background properties of an HTML element.
The following examples use Cascading Style Sheets (CSS). CSS is the best way of setting the background properties in your HTML. It's more flexible than the (outdated) HTML method (more on that below). Using CSS, you can set the background properties of any HTML element. Plus you can do things like, specify an image's position, whether it should repeat, how it should repeat etc.
Background Color You can set the background color of any HTML element using the background-color property. You can choose a background color with the HTML color chart.
HTML Color Codes Use this page to get HTML color codes for your website. The colors are represented by their hexadecimal values (the most common method for the web). On the color picker, you can also see the RGB values (you can use these for the web too).
Example of HTML color code usage:
To learn more about HTML colors and how to apply them to your website, check out the HTML colors section of the HTML tutorial.
5/11/2016 10:20:28 AM • EliteGroup... • Answered on May 11, 2016
Computer will not enter bios during boot
PRESS F2 or del if you have usb use a an adapter for a ps2 connector from the keyboard will probably help to set your bios settings maybe replace your backup battery when you have lost your settings.
2/14/2016 12:19:59 PM • EliteGroup... • Answered on Feb 14, 2016
Ecs 848p-a v1.0
The manufacturer's support page for this motherboard can be found at the following link http://www.ecs.com.tw/website2008/Product/Product_Detail.aspx?CategoryID=1&DetailID=361&DetailName=Feature&MenuID=24&LanID=0 Perhaps the answer to the question you have not asked is found there.
9/8/2015 6:14:13 AM • EliteGroup... • Answered on Sep 08, 2015
P4S5MG/GL+
A manual for this motherboard can be found at the following link http://download.ecs.com.tw/dlfileecs/manual/mb/eng/p4/p4s5mggl50eng.zip In the downloads section of the support for this board, there was no "Auto Setup Program". Downloads from the manufacturer for this motherboard can be found at the following link http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=42&CategoryID=1&MenuID=18&LanID=0#fragment-Download
9/8/2015 6:11:13 AM • EliteGroup... • Answered on Sep 08, 2015
Where is the battery
If you are asking where the CMOS battery is located, you will need to firs provide the model number of the ECS EliteGroup motherboard. Here is a link to help you locate yours http://www.ecs.com.tw/extra/productinfo/MB.htm
9/8/2015 5:43:48 AM • EliteGroup... • Answered on Sep 08, 2015
Hello there please guys help me I bought ecs elitegroup motherboard but it doesn't detect my g210 invidia geforce after plug my graphic cart it shows strange lines
suspect you may need to disable the motherboard built in graphics card and tell it to use PCI graphics adapter otherwise an interrupt conflict in CPU and possible conflict as both devices compete for same computer resources.
8/15/2015 1:38:38 AM • EliteGroup... • Answered on Aug 15, 2015
I cannot find my administration key that is needed at the end of my installation of my motherboard. I cannot find the code in the box. Where is it?
Hi, Could you elaborate? I have never heard of this... unless you are talking about the Administrator password Windows asks for during install... which you can typically just leave blank and continue the install...
1/31/2015 8:52:47 AM • EliteGroup... • Answered on Jan 31, 2015
0answers
0answers
LAPTOP l41sa1
Be the first to answer 6/9/2014 4:31:05 AM • EliteGroup... • Posted on Jun 09, 2014Be the first to answer
EliteGroup C51GM-M Motherboard Logo
7 questions posted
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
realtek alc655 183 ac97 audio codec
  • Computers & Internet
