20 Most Recent
Nokia 2126 Cellular Phone Questions & Answers
Insert sim card
As far as I know there are two possibilities to get this error message.One is poor signal of that respective network for which you just need to switch OFF and ON your mobile and the mobile will be able to receive the signal from near by tower.You may also get this error message when you are trying to insert a sim other than which the mobile is locked to.To solve this problem you need to unlock the phone from that particular network or use the same sim to which the mobile is locked to.. You can unlock Nokia 2126 using unlock code, You can purchase such code from any vendors online like
Mobile-Unlocker.com
Tracfone dies after adding time
Same problem. Working off of Reijose's suggestion (thanks) I had the charging plug in the wall and the phone. That at least stopped the buzzing. Then I started working combos of buttons, turning the phone off and on etc and finally it came back to life. Can't say it was any one combo, but I did press 666 and clear or stop enough times that I might have finally exorcised the demons of of this thing.
Serriously that was the combo of buttons I used, through just by chance more than anything, ha.
What profile should i use?
Hi there, it all depends on your phone and where you are. For example General is loud silent is obviously silent and meeting it will not ring but only vibrate. Just try them all out.
I can hear other party
Hi, When you make a call and you can hear the party calling you and they can hear you, it means that,the mouthpiece of the phone which makes other party's hear you when you call is bad.
Also you can see if it is just dirt that is making it not to work.
It is located at the lower end of the phone.
Take care.
