20 Most Recent
Transcend StoreJet 80 GB USB 2.0 Hard Drive Questions & Answers
The 2 GB Store n
First thing to do is run check disk on the computer to be sure that file is not corrupt. The file name may be too long or not recognized.
5/5/2017 5:04:23 PM •
Transcend...
Answered
on May 05, 2017
Dropped my Transcend Storejet25p 5oo gb on floor !
Your hard drive is damaged beyond repair. When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death". There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
3/2/2015 1:37:57 AM •
Transcend...
Answered
on Mar 02, 2015
How to prepare Transcend StoreJet 25M3 for use with Acronis True Image 2014 backup Software ?
The disk size of 698GB under Windows is correct for a 750GB drive.
This tells you there is only one partition on the Transcend drive.
It is best to reformat the Transcend drive to NTFS, unless you need to also read from the Transcend drive using a computer that does not support NTFS.
I would expect Acronis backup inviting you to reformat to NTFS if you would try using a FAT32 drive for backup. FAT32 has a file size limit of 4GB which may impede backups.
5/3/2014 4:41:19 PM •
Transcend...
Answered
on May 03, 2014
PC not detecting HD
HDD not Detecting only if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
Thanks..
More Tech Support Contact
http://www.techsupportmart.co.uk/
2/6/2014 9:14:49 PM •
Transcend...
Answered
on Feb 06, 2014
Volume label
to change the volume label right click my computer and go to manage. in the left hand column click on disk management in the middle pane you should see you HDD and Disk drive and other things if attached,
right click the drive you wish to change the letter of and click on change drive letter
1/13/2014 11:04:09 AM •
Transcend...
Answered
on Jan 13, 2014
