20 Most Recent
Quartet gbc ShredMaster 950S Strip-Cut Shredder Questions & Answers
One of the clips which hold door close broke. thus, machine won't operate.
Does the door fully closing operate a safety switch? If so you might be able to get round this by clamping the door shut with(eg)a belt. Not the most elegant of solutions but it might work. I searched online and got a number of hits, one of which said that spares are not available. Not very encouraging! Try contacting manufacturer directly.
It is very noisy
if it is noisy, you have to open the shredder and check the gears if still ok.
if they are worn up they will make the noise
9502 is jammed and does
Try to run the reserve 1st and then wait for 5-10 minutes to cool down and try to shred again.
Make sure you do not exceed allowed number of papers for shredding to avoid paper jams.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
How to fix a stuck shredder
get a pair of needle nose pliers and pull the jammed paper out. (you may need to figure out how to pop off the top cover to get better access to the blades)
Plactic drive gears
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
