SOURCE: I have a gbc heatseal
There is a small 125 v 10 amp fuse in the circuitry on the right inside the unit. Whether or not this will solve your issue is unknown. I have one apart in front of me right now with other problems.
SOURCE: Unibind machine will not heat. Does heat if
I think it can be fixed. It appears that there is some kind of loosing inside the machine and when the machine is turned upside down it heats up because the electrical contact is made. If you can work inside such electronics, you may try to fix. IF NOT DONT TRY IT (there is a danger of electrical shock). Instead you may refer any repair/ service professional .
Hope it helps! Good Luck!
CreativeTECH
