likely to be toner on your thermistors - clean the thermistors and pick off pawls for the hot roller - i'd also check your web roll to make sure its not dry and make sure the press roller cleaning roller is clean
Printcopy.infohttps://printcopy.info > code=SC401
Code: SC401 · Description: Transfer positive electrode current error A transfer roller current leak signal is detected. · Causes: • High voltage supply board set ...
Missing: W2401 ' Show results with: W2401
Code: SC401 · Description: Transfer roller open error · Causes: • Transfer power pack defective • Poor connection between the transfer current terminal and the ...
If your Ricoh Aficio MP C2800 is showing "toner undetectable" messages for all four toner cartridges and the yellow and cyan colors are not showing up in copies, there may be several potential causes for this issue. Here are some troubleshooting steps to help you resolve the problem:
Check Toner Cartridges: Ensure that all four toner cartridges are correctly installed and securely seated in their respective slots. Make sure there are no protective seals or tapes left on the cartridges.
Shake Toner Cartridges: Sometimes, toner inside the cartridges can settle or clump, leading to detection issues. Gently shake each toner cartridge side to side to redistribute the toner evenly.
Replace Toner Cartridges: If the toner cartridges are old, empty, or expired, replace them with new, genuine Ricoh toner cartridges.
Clean Contacts: Dust or debris on the toner cartridge contacts can interfere with communication. Use a soft, lint-free cloth to clean the electrical contacts on both the toner cartridges and inside the printer.
Check Developer Unit: The developer unit in the printer plays a crucial role in toner development and transfer. Ensure that the developer unit is clean and free from any obstructions.
Perform a Firmware Update: Check if there are any firmware updates available for your Ricoh MP C2800 printer. Updating the firmware might address known issues and improve printer performance.
Reset the Printer: Power off the printer, unplug it from the power source, wait for a few minutes, and then plug it back in. Power the printer on to see if the issue resolves.
Check Toner Detection Sensors: The printer uses sensors to detect the presence of toner cartridges. Verify that these sensors are functioning correctly and not blocked by any debris.
Perform a Factory Reset: As a last resort, you can try performing a factory reset on the printer. However, be aware that this will reset all settings to their defaults, and any custom configurations will be lost
PrintCopy .infohttps://printcopy.info > code=SC390
Code: SC390; Description: TD sensor error 1. The TD sensor outputs less than 0.5V, 20 s after the TD sensor initial setting has been performed.
Missing: cod ' Must include: cod
Fixyahttps://www.fixya.com > ... > Ricoh
The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that ...
Copytechnethttps://www.copytechnet.com > 56632-sc-390-a
Sep 24, 2011 - I've got an Aficio 1018 that's generating sc390 after every 10 copies. I recently fitted new drum, cleaning blade and developer and changed ...
Question edited for a lot more clarity and toss in some CAPS.
Question moved to maker category.
Printer set to wrong size paper.
Computer word processing program set to wrong size.
For example Letter size paper in Printer and Legal size in the Settings of what is saying to print the document. The paper is too small.
The backup battery for the Ricoh Aficio SP1100sf is located in the control panel. The service manual does not provide specific instructions on how to replace it, but it does provide general instructions on how to maintain and troubleshoot the printer.
hi
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
