20 Most Recent
Maytag MGR5770 Gas Kitchen Range Questions & Answers
My Maytag convection oven has the heating elements
Stick a thermometer inside the oven. Compare the them inside the oven to the temp you see on the control panel; are they the same?You must do this first. You will note a disrepancy. If the oven temp and yours do not match, that you have solved the problem.Your oven sensor or thermostat might be at fault.
F9 notation on screen. Indicated prob w/door
Hi photoopdoc,
The "F9" error code fault description is about the door latch. The easiest way to correct this is by checking the door latch components. You may also try to unplug the unit and leave it for an hour or two, then plug it back in. Please refer to the additional codes below.
Sometimes F9 has some number after the error code.
F9-1 for latch lock upper
F9-2 for latch unlock upper
F9-3 for latch lock lower
F9-5 for latch unlock lower
F9-6 for latch both lower
Hope it helps.
Thank you for using FixYa.
Where is the fuse for
See the link below for the wiring diagram for your appliance - there does not appear to be any fuse. Take a look at the lower right-hand side of the diagram where the power cord is shown. If there is an overcurrent protection device, it should be in this area.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45709&diagram_id=28482941#d28482941
If the unit is without power, check the outlet where the appliance is plugged in. Also check the appliance cord and make sure it's ok. If you decide to go further, please be sure the appliance is unplugged first.
Be careful
WHen turning on the oven to bake it will not
This is usually a symptom of a faulty oven safety valve. Over time, it tends to stick internally and banging on it helps unstick it. You can either continue banging on it for faster burner ignition or have it replaced. You'll need the make, model # and sometimes serial # if it's an older model, to replace the part. If you do it yourself, be sure to close the shut off valve behind the stove before you remove it. Douglas
When I turn on the oven it does not start to heat
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
