20 Most Recent USA Spec SCD-A88 6-Disc CD Changer Questions & Answers
Need pinout for USA SPEC SCD-A88 CD changer
Sorry to hear it I had same prob with vw88e tried to email usa spec and get pin out but no results.. had to get the screwdrivers.. DO THIS ON A CLEAR TABLE WITH GOOD LIGHT !!face pops off easy enough ya gotta have 3 hands to gently hold ones youve popped and work the others then 6 little screws 3 on each side.. CAREFUL not to drop the little sliders for mounting in car they have springs that pull them out of thier home and they **** to get back in remove the top.you should be looking at the top now and can see the cartridge..and a little bit of the cd that was last playing.there's a large gear.. with a pin in a half moon with a little flat tail lookin slot. if the pin is in the little flat area, carefully spin the gear until its out of flat and around to top of moon. cd that was playing is now in cartridge.. on the bottom in the back is another little gear (Between the mechanical case and outer shell) carefully spin that gear until the disk selector is all the way down (if it goes up or doesn't move spin the other way) keep spinning until cartridge ejects if you want reassemble if you just wanted disks toss it as is if reassembling just go reverse face plate goes on last
9/1/2011 11:55:43 PM • USA Spec SCD-A88... • Answered on Sep 01, 2011
Sony cd changer
IF IT'S A FIAT BRAVA ORIGINAL CAR RADIO WITH A SONY CHANGER IT WILL HAVE AN INTERFACE BEHIND THE RADIO WHICH MAY NEED RESETTING IF YOU DISCONNECT THE INTERFACE POWER FOR 2 MINS AND RECONNECT IT FAILING THAT THE SONY 6 DISC WILL BE JAMMED, WHICH IS COMMON
11/21/2007 7:00:22 AM • USA Spec SCD-A88... • Answered on Nov 21, 2007
0answers
0answers
Acura tl hfl
Be the first to answer 11/14/2013 8:03:33 PM • USA Spec Car... • Posted on Nov 14, 2013Be the first to answer
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
4/18/2024 1:48:21 PM • Car Audio &... • Answered on Apr 18, 2024
Gathers car audio manual
How to change language to english for Honda Odyssey 2021 Gathers Radio Player
4/16/2024 4:19:39 PM • Car Audio &... • Answered on Apr 16, 2024
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
3/26/2024 3:40:48 AM • Car Audio &... • Answered on Mar 26, 2024
2answers
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
3/19/2024 7:56:21 PM • Car Audio &... • Answered on Mar 19, 2024
What demo mode the code for 4.91
'make model (what is is)' as first 3 words in all questions. https://www.google.com/search?q=demo+mode+the+code+for+4.91 ..
3/19/2024 2:42:25 AM • Car Audio &... • Answered on Mar 19, 2024
Xplore Amp 5553. How many watts RMS and impedance loads.
Unfortunately, no one knows or is telling. Companies rarely state power in RMS because Peak Power is a much more impressive. 1000 watt amp, 200 watts RMS x 2 channels at 8 ohms. Look for a sticker on the unit. https://www.google.com/search?q=Xplore+Amp+5553 ..
3/19/2024 12:23:13 AM • Car Audio &... • Answered on Mar 19, 2024
Carrozzeria serial abm760p57 RADIO ON ??
What is your question? Thank you.
2/28/2024 7:23:47 AM • Car Audio &... • Answered on Feb 28, 2024
2answers
I need the code
Your code is 1 3 6 3
2/25/2024 10:20:30 AM • Car Audio &... • Answered on Feb 25, 2024
6answers
USA Spec SCD-A88 6-Disc CD Changer Logo
6 questions posted
Top USA Spec Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you an USA Spec Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • USA Spec Car Audio & Video
Most Popular Question
sony cd changer
  • Car Audio & Video
