20 Most Recent
Champion UH-100B 40 Commercial Undercounter Dishwasher Questions & Answers
Dishwasher running hot
it sounds like the thermostat on the rinse tank is set too high, if you drop the panel on the bottom front of the dishwasher,you will see the rinse tank, usually on the l/h side,its normally a cylindrical shape,the hermostat is normally connected to this, usually there is an adjustable shaft on the stat, it might have numerical markings on it i.e 0 to 90 degs . MAKE SURE THE POWER IS OFF TO THE UNIT !!, THIS IS CRITICAL FOR TOUR SAFETY!!. if your unsure get a proffesional to repair it . shouldnt be too expensive , hope this helps .p.s if you do have a go the rinse temp should be between 75 and 85 degrees c .
Champion uh1ooB. Water continues to
Hi
Thanks
for using FixYa. To start with check the water inlet valve which is located
behind the lower access panel on the left or right side of the Dishwasher. If
the water inlet valve is bad you have to replace it, also check the main water
line for clogs/obstructions. If still the issue is not resolved then it’s a bad
float switch and needs to be replaced. Please do accept the solution if the
issue is resolved or post a comment for further assistance.
Thanks
Rylee
7/13/2010 1:18:44 AM •
Champion...
Answered
on Jul 13, 2010
DIO3T131FEUK Integrated dishwasher has power but won't switch on
Check Power Supply:
First, ensure that the dishwasher is properly plugged into an outlet. Sometimes vibrations or nearby appliances can cause it to come unplugged.
If it's plugged in, test the outlet by connecting a small appliance (like a toaster or blender) to see if it turns on. If it does, move on to the next step.
Check Circuit Breaker:
Verify if a circuit breaker has tripped. Go to your circuit breaker box and look for any tripped breakers.
If you find one, flip it to the "off" position and then back to the "on" position.
Test the dishwasher again to see if it powers on.
Child Lock or Delayed Start:
Some dishwashers have a child-lock feature that prevents accidental starts or changes to the wash cycle.
Check your owner's manual for instructions on disabling the child lock or delayed-start features.
Ensure that the dishwasher door is securely latched.
Reset the Dishwasher:
If the dishwasher has power but won't start, it might be stuck between cycles.
Allow any drain cycle to run (if applicable), wait for 60 to 90 seconds, and then press the start button once.
Unplug the dishwasher for a minute or two, then plug it back in. This can help reset the machine.
Refer to the owner's manual for any specific reset procedures.
If none of these steps resolve the issue, consider reaching out to professional repair services or the manufacturer for further assistance.
4/21/2024 2:44:15 PM •
Dishwashers
Answered
on Apr 21, 2024
Karcher Puzzi 100 Spray pressure low
troubleshoot the issue:
Spray Nozzle Blockage: Ensure that the spray nozzle is clear and not blocked. Sometimes debris or buildup can obstruct the nozzle, affecting the spray performance.
Pump Coil and Circuit Board: The pump coil could be damaged or broken. If it's faulty, the pump won't spray at all. You can check continuity through the coil and verify that the switch is supplying power to the circuit board and, in turn, to the pump. Dry solder joints or a failed smoothing capacitor on the circuit board can also cause issues. Pumps are relatively simple solenoid plunger types, and replacements are available for around £40-£50. If you're not comfortable testing at mains voltages, seek professional assistance.
Calcium Buildup and Blockages: Some pumps can be dismantled, allowing you to remove any calcium buildup or blockages. Gently tapping or shaking the pump might get it going. Recirculating a descaler can also help clear buildup without disassembly.
Pump Replacement: If the pump is indeed faulty, consider replacing it with a new one. It's advisable to change the circuit board (PCB) as well. If you're unsure about electrical testing, consult an expert.
Remember to follow safety precautions when dealing with electrical components. If you're not experienced, seek professional help to avoid any risks. Good luck with resolving the issue!
For reference, the Karcher Puzzi 100 is designed for gentle and effective cleaning of small to medium surfaces, especially carpets and upholstery2. Its spray pressure is around 1 bar, and the spray rate is approximately 0.26 gallons per minute. If you need further assistance, consider referring to the Karcher Puzzi 100 user manual.
4/20/2024 10:55:08 PM •
Dishwashers
Answered
on Apr 20, 2024
Can't get dishwasher out from underneath the counter
Question edited to move it from Computers to Dishwashers.
Is there by any chance a floor tile 4" out from the dishwasher front? If so, try lifting the front with a crowbar or long screwdriver.
Did you disconnect, inlet hose, drain and power? They may have been installed tight, or clipped.
4/19/2024 6:24:59 PM •
Dishwashers
Answered
on Apr 19, 2024
HOW TO REPAIR A HOLE IN MY DISHWASHER
It depends upon the material you are trying to repair but Araldite or any good quality two part epoxy will suffice to fill the hole.
Ensure the area is dry and clean then build up the repair . Larger holes will require multi additions of epoxy.
4/15/2024 10:01:23 PM •
Dishwashers
Answered
on Apr 15, 2024
WINTERHALTER MODEL MTR3 GIVE ME ERROR 22.2 AND ERROR 12.1
These error messages both point to a sensor problem.
Error 12.1
This error is related to the boiler temperature sensor. Consider the following:
Look for a short circuit in the sensor. Inspect the cables and plugs for any issues.
Ensure the sensor is correctly connected.If needed, replace the boiler temperature sensor.
Error 22.2:
This error pertains to the tank temperature sensor. Possible causes include:
Short circuit in the sensor.
Cable failure or plug failure.
Sensor not properly connected.
You may need to check the sensor wiring, connections, and replace the temperature sensor if necessary.
4/3/2024 6:11:13 PM •
Dishwashers
Answered
on Apr 03, 2024
