20 Most Recent MSI Mega 180 Barebone Questions & Answers
0answers
Integrated graphics card doesen't show
try to remove the cmos battery to reset
10/12/2010 10:06:18 AM • MSI Mega 180... • Answered on Oct 12, 2010
2answers
How do i download MSI N082 graphics driver
To get the MSI N082 graphics driver: 1. Find your graphics card model. Note down the model number. 2. Go to MSI's website. 3. Look for the support or downloads tab and click on it. 4. Use the search or menu options to find drivers for your specific graphics card model. 5. Download the driver package. 6. Run the installer file once the download is complete.
3/26/2024 10:36:50 PM • MSI Computers &... • Answered on Mar 26, 2024
Screen does not fit after adjusting the screen resolution msi N082 i tried updating the VGA driver online but it keeps telling me that driver is up to date
If adjusting the screen resolution didn't resolve the issue and you've already updated the VGA driver, try manually adjusting the display settings through your computer's control panel or display settings menu. Look for options like overscan or scaling to ensure the screen fits properly. If the issue persists, it could be a hardware problem or compatibility issue with your monitor. Consider reaching out to MSI support for further assistance.
3/26/2024 12:50:33 PM • MSI Computers &... • Answered on Mar 26, 2024
How do i connect my fire stick thru bluetooth on my MSI windows 11 laptop??
To connect your Amazon Fire Stick to your MSI Windows 11 laptop via Bluetooth, you will need to follow these steps:
  1. On your Fire Stick, go to Settings > Display & Sounds > Enable Bluetooth.
  2. On your MSI Windows 11 laptop, go to the Windows Settings > Devices > Bluetooth & other devices.
  3. Turn on Bluetooth on your laptop and make sure that it is in pairing mode.
  4. On your Fire Stick, select your laptop from the list of available devices.
  5. On your laptop, click "Pair" when prompted to complete the pairing process.
  6. Once connected, you should be able to stream content from your Fire Stick to your laptop.
1/20/2023 11:59:27 PM • MSI Computers &... • Answered on Jan 20, 2023
Wanting to connect an older AV received to my Win 10 PC via optical input. Should I use MB or Graphics output?
You should use the audio output on your computer that is labeled as "optical" or "S/PDIF" (Sony/Philips Digital Interface Format) to connect to the optical input on your AV receiver. This will typically be labeled as the "digital audio out" or "digital output" on your computer. The "graphics output" is used for video, not audio.
1/12/2023 2:39:40 PM • MSI Computers &... • Answered on Jan 12, 2023
How can i enter the bios on my pc.
Proper training and equipment are needed to modify the (Basic Input Output System ) BIOS on a PC. You could turn your PC into a paper weight. The game has been criticized for its anti-cheat software, Vanguard, as it was revealed to run on akerneldriver, which allows access to the computer system.[56]OSNewsexpressed concern that Riot Games and its owner, Chinese technology conglomerateTencent, could spy on players and that the kernel driver could be potentially exploited by third parties.[56]However, Riot Games stated that the driver does not send any information back to them, and launched abug bounty programto offer rewards for reports that demonstrate vulnerabilities with the software.[57][58]The bounty will reward white hat hackers between $25,000 to $100,000 for reports on its vulnerabilities, with the pay being based off the severity of the exploit.[59]Gameplay bugs do not qualify for this bounty.[59] Valorantwill not run onWindows 11if the system does not have aTrusted Platform Module(TPM) 2.0 compliantcryptoprocessorandUEFI secure bootenabled, as mandated by Microsoft's minimum system requirements for the operating system.[60]
11/20/2022 7:19:17 PM • MSI Computers &... • Answered on Nov 20, 2022
Replacing an msi laptop screen
no PC told at all MSI is maker only but yes they all unplug on laptops(is it) they are held on by tricky ways and if forced you break mobo or display there are the easy ones push on pull off the the wedge locked, , unlocked first. and last the hinge lock FFC cable ends learn not to force them, look first for locks, 2/3rs of them are locked.
8/22/2022 8:33:42 PM • MSI Computers &... • Answered on Aug 22, 2022
I need the MSI MS7506 AMD AM2 Bios bin file
Contact AMD.
8/1/2022 10:43:59 PM • MSI Computers &... • Answered on Aug 01, 2022
I was using Sony
the reason you get lost is using bummer APPSlike nero or worst. doget Imgburn , free and safe and solid.use test mode.the do a test mode burnit now tells you exactly what fails. (sure does)and this is why, sure is.(filenames too long or?)"I know some units require a specific brand of blank CD" this is not really true.no player or burner has ODD media restrictions on brand. (ODD disk are really PnP disks that have ID track that tells the host what the disk can do, in every possible way)sure there are vast brands that are pure trash sure.just like tires car or the like. BRAND WISE.like old Firestonedeathtires. (cured by new owners)The Imgburn does fail on bogus medialet me explain, gee seen it all I havethe china import CD-r. has the ID track all configured illegallly, is invalid. so the burner warns of that pronto.a blessing that, like :::: illegall(sic), disk size or makers name missing or the burn limits stated are missing (useless hard nut fail here)a burner can not burn lacking this key ID track set correctly by the maker ( a must be good thing)a classic case of pure junk CD-r or DV-R or BD-Rtry TDK and verbatum and end this junk grade folly.
6/14/2022 3:45:01 PM • MSI Computers &... • Answered on Jun 14, 2022
The first of four led lights FLASH ON and 0FF ON A970-G46 MOB AND MY POWEER SUPPLY TESTS GOOD. All componets work good on my 2nd identical MSI MOB. CAN THIS MOB BE FIXED OR MUST I REPLACE IT?
four led lights where are they? lost the manual? Desktop mobo. MS-7693 (v2.x) Manboard 970a or 970S? all led x4 status indicators. on mobo top 4 glow means phase 4 power level. page 32. coin cell dead is #1 for all PCs over 5 year and for sure 7. a dead mobo, bios screens dead, that it,???? what gpu card what monitor ? all fans dead? support for vista or w7 , so that? bios HOT KEY IS <del> THEN F11 (BIOS II)? 2 MOBO 1 GOOD 1 BAD USING SAME CPU AND 1 STICK OF RAM.? same PSU>? wired same to mobo? THIS MOBA HAS NO VGA IGPU PORT ON REAR SO MUST HAVE GPU CARD or there can be video ever. and see bios. and reset bios first and new coin cell first. 7years old that coin is and will be a pain now or soon. a $ 1 fix. gpu card into top x16 slot????? GPU card over 75watts must have gpu aux power wired to it or it will be dead, from PCl. psu wired to JPWR2 ? must be. and JPWR1 both. or cpu will be dead. that is about it , on this 2011 mobo. no gpu card top in fact full speck on all things connected to the mobo no told, including all devices all cables, and cards. and port. not told.
5/23/2022 4:34:28 PM • MSI Computers &... • Answered on May 23, 2022
Can't enter bios (MSI 870AG46) the puter boots and runs the RAID setup and displays the 5 options, after exiting it skips the BIOS setup screen.
NO OS TOLD AT all and want help<. really? I will guess w7 ! Bios hot key is <del> on pad , numlock off. NO drives told tell me it is sata boot, drives not relic junk IDE (pata) in bios disable raid and save BIOS main <DEL'> hot key. the coin cell is dead why skip act 1 ? 7 years old is max life. EOL so replace that first reset bios inside bios see time and date set raid CHIP OFF, in bios set boot order of HDD 0 boot is there and good HDD safe exit cold boot it. install w7 is max ,w8 up lacks key drivers for the mobo seen below. link to makers site if your read the manual and see page on control+F RAID rom there all you need is there, in that free manual. page 72 B2 quote "Important Be sure to enable the RAID functon for SATA devcen BIOS before configuring the RAID Opton ROM Utlty." the means same in reverse too, to disable radio do so on main bios there are to bios here,main and raid. page 48 https://us.msi.com/Motherboard/870AG46/support#manual books there and all w7 drivers too. main raid mode, (off)
5/23/2022 4:06:02 PM • MSI Computers &... • Answered on May 23, 2022
The dvd drive on my msi cr610 laptop will not
load VLC program free from France not told burned with what, not told files there does explorer see the files, first. mp4 file or real DVD formatted structures with Video_TS folder and vob inside? nobody can guess what you burned there and there are like 100 video formats to put there, not one can I guess.
5/23/2022 3:01:36 PM • MSI Computers &... • Answered on May 23, 2022
Can i instal CPU AMD Athlone 64 x2 6400+ 125w in to MSI MS-7351 VER 1.3 NEC VL370 Socket AM2 Motherboard?
only MSI can answer that ask for the QVL list of CPU for this MOBO MS-7351 ask them only on their web site, qvl is qualified vendors list of part for CPU or DDR the bios must like it, is one factor. of many. and only THEY know that, BIOS is never documented too well. and this mobo now has zero support there.
5/23/2022 2:58:34 PM • MSI Computers &... • Answered on May 23, 2022
Hi, I have a MSI GT660R, when I turn on the power,
MSI GT660R(2010) 7 years old, and coin cell is due on 7 year mark. power off remove huge battery , sorry 7 years they fail easy put back AC power pack. and run on AC power only ok did screen wake up>? show MSI splash screen first it must. not there are more tests.
5/23/2022 2:45:02 PM • MSI Computers &... • Answered on May 23, 2022
How to reset power ic on laptop?
no told ,model no photo of bad screens, gee we need to see them. why no ask them what power IC means. to reset any laptop old we:
  1. remove huge battery first. run on AC power pack only.
  2. hold power button for 10 full seconds. and release, power i reset.
  3. bad coin cell is next to replace. then reset bios inside BIOS. page 1.
  4. set time and date and boot order to hdd0.
  5. save
  6. exit bios
  7. cold boot it #2 above
5/23/2022 2:38:01 PM • MSI Computers &... • Answered on May 23, 2022
I have a MSI 7091 Ver 2 Motherboard. The entire IO panel is not working and I cannot get into the BIOS to enable USB Legacy support. I have heard there is a PCB fuse that protects the IO panel and wou
2004/5 junky and zero support mobo post. NO OS TOLD At all of VAST not one tiny clue and is needed use a USB port unless USB is dead in BIOS but not told that either.. do not flash your bios or you will brick he PC, you heard wrong, as is normal 1/2 what you read on the internet are pure lies or full evil. there is no fuse. all we know is this MSI 7091 Ver 2 (old) 2004 Msi ended all support now, zero results there. nothing else, no PC told at all what is in the case a secret. no PSU told no if 4pin and 24pin power are connected to mobo. keyboard USB dead? that it in BIOS not told that. this MOBO has no VGA rear port at all, it is iGPU free, has none. so BIOS is dead due to no video card installed and if has one installed none told, and some are dead lacking 12vdc aux power not connected to the GPU card directly, oops failure #1 915P chip set relic MOBO pentium 4 old dog CPU the ICH6R chipset runs the rear USB ports even in bios full time. the keyboard needs to be connected to USB2, port 1. P4 has no igpu on the die/chip, so none there, and no vga port there. 1: coin cell is dead this old. AND ALL MOBO JUMPERS SET RIGHT.. 2: all via lan chip dead, for newer OS ,VIA IS zero support. 3:BIOS only works with GPU card, usb rear + keboard 4: cpu correct type p4, and no bent pins bought off fleabay. 5: 1 stick of DDR1 RAM. 1GB MAX PER STICK, 6: MOBO JPW1. MUST HAVE PSU POWER HERE.+ATX1 7: POWER ON NOW, AND BIOS WILL WORK 8: relic MSI mobe only PS2 keyboards work for BIOS hotkeys. BIOS HOT key (setup) some use ,<DEL> key on keypad (numlock off !!!!) or needs this keyboard 2004. . or PS2 + F2 key. (or F2 ,f1, f2) dance, wild but is prompted. the only manual on the web for his old dog does not cover bios at all, lost in the sands of time. it. P4 is year 2000 to 2008 , 915p is 2004 so is this. thing a relic and hard too find MSI facts this junk. zero support means junk in my book. ms-72xx here, the PC prompt you clearly and then tells F11 is boot menu, last at end of POST v1 not 2, v2 docs rare more. http://msi-ftp.de/Manuals/Medion8383XLmitMS-7091.pdf 7200-undefined-undefined-0.jpg
  • new coin cell,
  • good VGA card put in top x16 slot.
  • ps2 keyboard
  • Del key to bios(numlook off) reset bios now.
5/23/2022 2:34:11 PM • MSI Computers &... • Answered on May 23, 2022
My msi vr70s runs with Ubuntu operating System. I want to change to windows 8. How do I do that?
you cant, now,. w10 buy it , and load it. THIS IS SHOPPING QUESTION. SO WHY NOT GOOGLE IT FIRST AND CLICK SHOPPING ICON We can not shop for you, no country told. MS has the ISO w10 for free and you can in fact run w10 for free, if not having personal settings allowed. MS even states that clearly there. run for free. example , no themes allowed but who cares? the answer is here, at , amazing microsoft.com w8 was bust, a flash in the pan and grand dad said. here it is at MS the w10 media builder , you boot it and answer silly questions. https://www.microsoft.com/en-us/software-download/windows10
5/23/2022 1:26:00 PM • MSI Computers &... • Answered on May 23, 2022
No SATA on my ole K9N2 SLI Platinum mobo...Help?
2008 mobo, needs new coin cell for sureno photos of he melted parts]no tech on earth can guess that , lacking clear photos. best leave it alone and a heat gun will wreck easy the SMD low temperature rated solder !!!just above cpu area are VRM, and mobo is now junk.VRM = voltage regulating modules,chip bank.nothing kills electronic faster than heat ( drowned or lightening worse)why use a heat gun ever, it only causes more damageor SMD parts that fall loose or off and those are low temp soldered.ROHS spec.next time post photo first,so techs can see the damage with eyes !if the coin cell is dead, (sure it is)boot driver hide.when the coin cell dies, bios settings all 128 or moreare lost. and bios goes mad and even lies to us.(expected)and the cure is what. a new coin cell.sold at walmart, lane 15, CR2032.for a buck.new coininsertedPower on hammer bios key, see page 1click choice reset bios to defaults. (or known config)set time and dateenable all usb and Sata ports in bios;set boot order to hdd0 first. or as you needsaveexit bios.cold boot PC. if hdd is not bad or OS not missing , windows runs. if not , then not.we test all HDD using the smart tests, on 2nd PCif smart fails the HDD is bad, no if's and;s or but'sthat is a hard fast rule.
5/23/2022 12:27:40 PM • MSI Computers &... • Answered on May 23, 2022
Msi x370 no bios. won't go into bios. did jumper did cmos.
wrong CPU used, it has no igpu on die of CPU4800 has it yours does notso buy a GPU card and usethatread the manual how to set that up inBIOS (DEL)key (num lock off)reset the bios if bios acts oddjumper JBA1, with GPU card installed (page 37 RTM)this will enable the card, to default it.then what port works on that card (vast exist) some have 3video portsand some only work in bios others nothigher end cards all 3 work, even HDMIif DVI on card, use it first or via VGA to DVI adapterif HDMI fails on card under BIOS.i have boxes of cards here and all this is true.try a GTX1650
5/6/2022 4:01:25 PM • MSI Computers &... • Answered on May 06, 2022
MSI Mega 180 Barebone Logo
Popular Tags
2 questions posted
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MSI Computers & Internet
Most Popular Question
integrated graphics card doesent show
  • Computers & Internet
