20 Most Recent
Delfield F2987C Questions & Answers
Primera cutting out
Hi, Sounds like you have an air leak in the fuel system, the easy way to find where the air leak is to whilst engine running try using washing up liquid around inlets & outlets if it bubbles then you found the leak probably on the intake side more than anything. Please leave me feed back: Malcolm Campbell, Thanks.
Need to repair a pluged cappilary tube
Your best bet is to order an OEM capillary tube and replace it. Of course this requires recovering the refrigerant. The likelihood of unplugging one is very very slim unless it is a very large bore tube.
11/21/2019 9:22:22 PM •
Delfield...
Answered
on Nov 21, 2019
Superheat subcooling
the model says that this is a cooler/freezer combination unit. super heat has to be measured on each section separately. As a general rule: Freezers run around 6-8 degrees and coolers are 8-10. I have seen freezers go as low as 4 degrees right before they hit set point temp and shut off.
6/29/2017 2:16:26 AM •
Delfield...
Answered
on Jun 29, 2017
