20 Most Recent
Fisher Price Lights _ Sounds Trike Batman Riding Toys for DS Questions & Answers
The power switch is not
Replacing the power switch can be difficult on some toys. Does the game operate on batteries? Or plug into the wall? If it operates on batteries then you can take it apart and find the two wires on the switch and twist them together. This will make the game have power on all of the time and you will have to take the batteries out to turn it off. Or you can replace the switch with a toggle switch from any hardware store. It won't matter which terminal you hood the wires to. Same goes with the switch on the type that plugs into the wall. Just make sure that you have it unplugged. With the new toggle switch you will have to drill a new hole to put the switch in.
I have the fisher price cool school computer but
I would first try and find the website for your game ( I did not have the full name of the game) and see if you could download what ever you need.
Or I would try and contact the company by phone( there should be a number on your game case) and ask for an Installation disk.
Hope this helps.
Mac compatible computer cool school???
If you have a modern (Intel) Mac running Leopard, you can use BootCamp, which is on your computer, to install Windows XP or Vista on your computer in a separate partition and run the software there. Other options that are a little simpler include using Darwine, a program that can run *some* Windows applications on Mac. The easiest solution would be to return the product to the store, because these companies are unlikely to ever produce a Mac client for your product.
Lost users manual
Hi
U can download the user manual from the company website itself..
thank you
Will 83069-U18 controller work on a PS2 please?
The Nyko Core Controller 83069 is a versatile controller that is compatible with both PCs and PlayStation 3 consoles1. However, there is no specific information available about its compatibility with a PlayStation 2 (PS2). It's always a good idea to check the product's user manual or contact the manufacturer for the most accurate information.
If you have a PS3 or a PC, you should be able to use this controller. Please note that compatibility can sometimes depend on the specific model of the console and the controller's firmware version
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
Solitaire Customer Service Call 1-8O5-225-6690
We are 24 Hour Available Call Now
Well you really didn't loose them.
What happens is Hp puts in the software of a whole bunch of games where after time you have to go to their site and purchase their games.
Well there are other FREE sites to goto to find Solitaire, free cell, Spyder solitaire and such.
I also think that they meybe hidden files in Windows, but to find them you have to remove Hp games and then do a search
When the game turns on
Pokemon crystal is a Game boy color game, there for it will not run the original Game boy.
What are some good catering services?
I recomenr you Alchemiq, it is a quality caterers https://alchemiq.com/catering-nyc/. They offer gourmet appetizers, fancy food stations, upscale cocktail catering, and event design
Recommended System Requirements
Find out if you can run that game on your PC Learn about. System Requirements Lab
www.systemrequirementslab.com
you can find here the minimum and required system requirements for most of the games and the updates needed for you to download to make the games run on your system.
Update profile
Clear your question, because which types of profile update. Then i better answer given.
Thanks.
Well i got the new
Unfortunately, your Logitech controller uses the DirectInput control standard, and Deathly Hollows Part 1 will only work with the new XInput standard introduced in Windows 7. The only Xinput controller so far is a 360 controller hooked into the PC. There are also some software emulation solutions, but those can be a bit tricky and buggy to use. For the best experience, I'd recommend purchasing a 360 pad and the corresponding wireless sensor.
