20 Most Recent
Nokia 1100 1600 2310 Questions & Answers
How to fix my nokia 110 ? it only flash white in the screen and suddenly off. . please help
Dear friend,
Your possible causes are:-
1. Its happening because your battery is not geting charge properly, and it gets discharge as soon as you switch on your mobile. So, make sure your battery is getting charge properly.
2. Make sure your battery is properly touching the pins of your mobile, clean the pins of your mobile with cotton and terminals of your battery also, then connect it properly.
3. Since your mobile is old, it has grown problem in internal I.C., to rectify this go to some mobile reparing shop or nokia service centre. They will fix your problem!
Regards,
Priyank Abhineet.
Restriction code for Nokia 2690
It is normally recommended you Don't post your IMEI on websites. It is a security code for that phone.
Usually the IMEI number has to be reset by your network provider. It normally cannot be done directly from the handset. Did the handset accept the new sim card. Some handsets can be locked to a specific network and changing network can stop your phone from working.
Nokia 2730C-1. can I unlock the network
If the phone was not used 2012, the phone number and phone have been deactivated from the network you used to pay for service. You need to set up a new contract as they expire after about 2 years of inactivity.
Backup contacts from broken nokia 2730c-1
Yes, there is a solution to backup contacts from your broken Nokia 2730c-1.
Before flashing the phone, one option is to try using Nokia Suite software on your computer to connect to the phone and backup the contacts. Another option is to remove the SIM card from the phone and insert it into a different phone to access and backup the contacts. You can also try using third-party software or services that specialize in extracting data from broken phones. It's important to act quickly to ensure you don't lose any important numbers. Good luck!
