20 Most Recent
Sony FD Trinitron WEGA KV-32FS16 32" TV Questions & Answers
Factory reset sony tv
Sony Google tv can't make factory reset went I try I just have a black screen help please
5/6/2016 10:08:02 PM •
Sony FD...
Answered
on May 06, 2016
No signal
can you please give some detailed problem of your tv.
10/5/2012 12:42:14 PM •
Sony FD...
Answered
on Oct 05, 2012
PIP will not go off.
Try unpluging the unit 5 min then pres and hold power button 10 seconds (this should reset ir!
4/11/2011 6:12:11 PM •
Sony FD...
Answered
on Apr 11, 2011
THE TV REMOTE DOESNT WORK
You will need to try another Sony remote o make sure it is not the TV causing the problem IF you have no access to another remote. MOST good TV shops can check the remote with an infrared detector. WE do it all the time.
2/18/2011 2:32:40 PM •
Sony FD...
Answered
on Feb 18, 2011
Turns on the turns off will not stay on
the problerm there is a busted capacitor inside have a look and see what one it is then order a new one and fit it if ur able to i could guide u through it if i can solder i am a tv technician
1/20/2011 1:19:59 AM •
Sony FD...
Answered
on Jan 20, 2011
Picture is cut off on sides
With TV powered off, use remote control to successively hit DISPLAY, 5, sound volume +, and POWER all within a second of each other. This takes you to the Service Adjust Mode and the first thing that appears is the Horizontal Size Adjustment "HSIZ". Press numbers 3 or 6 to make the picture larger or smaller. Other things can be adjusted by using numbers 1 or 4 to go through the list but you could really screw up your TV so don't do anything unless you are sure about it. When you're finished hit MUTING and then ENTER to save the changes.
10/2/2009 4:12:50 PM •
Sony FD...
Answered
on Oct 02, 2009
Won't turn on; it makes a click sound, and the red
Hello Cat 1 the problem that your tv set is having is coming from the flyback or high voltage circuit which has something to do with the flyback transformer most of the time it is just bad solder on that circuit but it can also be a faulty component,the click that you hear is coming from the start up relay that wants to turn on the tv set but the protection circuit in the power supply section is not letting it do that so this is the reason y your tv set is not turning on, what i would suggest is to have a service tech come out there and troubleshoot that section of the tv set and find out which component is giving you this problem thank you and hope this helps.
8/22/2009 4:52:51 PM •
Sony FD...
Answered
on Aug 22, 2009
I have to press the power button. The video is
You need to look at the vertical IC on the main board. It has seven pins. Clean off solder from pins with solder wick. Clean off with flux remover. wipe clean and resolder the IC. This should repair set. This is a common problem with Sony TVS.
6/26/2009 5:20:08 AM •
Sony FD...
Answered
on Jun 26, 2009
Line across top of screen
If the picture is ok otherwise then only thing that probably needs to be done is a vertical height adjustment. That is if the lines never changes position from cold to hot.
1/26/2009 4:54:06 PM •
Sony FD...
Answered
on Jan 26, 2009
Digital tuner?
Good question, Mike. I wondered about my fs210 model, too, and I found the answer at a Sony tech-support site.
1. Go to: http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DOCS
2. Enter your TV's model number, which, in this case, is: kv-32fs100 (and then click on Continue).
3. At the resulting page, under "Support by Type" in the left margin, click on "News & Alerts."
4. At the next page, click on: 04/02/2008: Critical: Is my Sony® television ready for the Digital TV (DTV) transition?
5. Your TV and mine are analog, but scroll down the page mentioned in #4, above, to see all of your options.
Consumers can determine whether any Sony TV is digital, just by entering the model number and following the steps listed above. ~ Kind regards, Gilda M. (replied 1/23/09)
1/23/2009 4:34:57 PM •
Sony FD...
Answered
on Jan 23, 2009
T.V. screen is green with bright horizontal lights top to bottom
There are 2 possibilities of green screen in this model.
1- Driver circuit of green gun is defective.
2- Screen itself is defective.
Now I want to know, do you have TV repair experience and basic electronics knowledge to test and check above 2 sections in TV?
1/10/2009 9:15:35 PM •
Sony FD...
Answered
on Jan 10, 2009
Cannot turn it on
check the pulse wire and anode cap if it is connected tightly, then if ok the false is the flyback transformer
12/7/2008 2:58:06 PM •
Sony FD...
Answered
on Dec 07, 2008
Enlarged Picture
yes it is fixable.
this problem is due to more supply is going to h/output stage.
please check
1 power supply for more voltage then normal.
2 component failure or settind in horz. stage to be checked.
3 print crack in h/output stage
you can not control from remote control.
9/29/2007 3:31:41 PM •
Sony FD...
Answered
on Sep 29, 2007
