Sony trinitron kv-32fs16 reset parental control
SOURCE: sony 32" trinitron kv=32fs16 tv problem.
I had the same problem 3 years ago. I called in a Sony tech and he said this was a common problem with this model. He replaced several resistors and resoldered several "Coaled Solder" connections. The repair ran $187 but the set has run great ever since!
SOURCE: young son locked tv parental control
Under the main menu, go to the Parent tab and enter the Master Password: 4357. This will completely clear the present password. You can enter a new one afterward.
SOURCE: kv-32fs16, no picture or sound , red lights flash 4 times
Hi
In sony tv`s the 4 blink code(sony error codes)usually means that there is a vertical deflection problem.
It is often caused by a faulty vertical output i.c and/or related components.
If you feel handy with a soldering iron let me know and i`ll help you with it.
Hope this help Merry Christmas
SOURCE: Parental Lock Control onto a
That model does not have a V-Chip, so that is not possible.
Please remember to rate my solution. :)
SOURCE: sony trinitron wega KV-SZ292NH0 factory reset
Download the service manual to your tV from net. It will have all details.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
OK
1 Press POWER to turn on the TV.
2 Hold down RESET on the remote control.
on.)
4 Release RESET.
OK.
