20 Most Recent
Philips 20PT643R 20" TV Questions & Answers
I need circuit diagram
The circuit diagram is in PDF and cannot send by this window. If you wish some details about it, check the site linked here.
Pull up previous posts by its left sidebar, or type in the
brand name and model number to of your set, to its search box, and press '
Enter'
or view it in
Mosaic / Timeslide option.
Tv not responding to remote
Hello
You just look onto its front panel control buttons for any struk or fault. These are microswitches, soldered diretly onto a printed circut board and comes just behind tthe front control panel. If some of them make contacted permanantly, that is , it does not disconnect, or jammed, this kind of fault will occur. As it is a 20" TV, it is very easy to locate these switches. You have to open your TV for replacing these switches. Just resolder one amoung it and go for a same type and number. Replace all of the at one instance. These switches are not so colstly, and easly avalilable in any electronics spare part shops. Just look its leg confugutration and height. OK.
Picture Tube Failing
HI...
I t sound like the De-gauss circuit has failed.
De-gauss demagnetizes the TV tube so you dont get what youre seeing.
It could be something as simple as a solder joint on one of the parts in that circuit. I fixed my Panasonic that way
Av Channel
The SVHS channel comes up if there is an SVideo cable plugged in. If SVHS comes up and there is nothing coming up, the input board is damaged. In which case a new TV will probably be your best option.
Tv not coming on
Your TV will probably not work on 95 volts. It may even damage your set. To see if your TV is still working properly you need to find a source of 108 volts at the minimum. Why is your voltage so low? Are you using a meter to check it?
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
